Home > Maintenance & Modifications > Fitting towing electrics... Do I need a split charge relay?
Jampot1979
Hi,
Thinking of fitting towing electrics myself after looking at the guide on here. My question is.... Do I have to fit a split charge relay? Thinking of fitting 12N & 12S sockets.
If fitting my own sockets to the car like in the guide on here, when caravan/trailer is hooked up, do you get an additional audible sound to say all is well and working?
Been looking online at universal kits and some come with audible and split charge relays etc.
When towing a caravan, I would like to be charging the leisure battery and powering the fridge while driving. Don't want to risk draining my car battery when not driving.
Post #600995 Mon Jun 29 2020 3:12pm
When the caravan indicators are working you get an addition light in the dash.
No crappy buzzer Laughing
I don’t think you need a split charge relay
If the fridge draws more than 10A you need a relay maybe wise to fit one if u will use it lots
Post #601009 Mon Jun 29 2020 6:13pm
Jampot1979
Yep... Razz
Been looking at universal kits, some come with a bypass relay (if car has canbus).
Is that required on an 08 Sport if taking feeds from the tow connections in boot.
Post #601067 Tue Jun 30 2020 6:11pm
No it’s not required.
A lot of cars have connectors for towbar in the boot. These are used at the factory if you specify a towbar option from new
These offer a far superior result when used and they are much easier to connect to like you are doing now.
Post #601069 Tue Jun 30 2020 6:48pm
