Home > Technical > faults on suspension system
keith63
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Hiya Gents
Ok got an issue now with the suspension ..
i have ordered a replacement AMK unit , ready to install tonight
But although the suspension system is tied into the Brains of the car , i believe most of this is via sensors all over the place .
In theory the actual suspension system should be quite simple
Air is sucked into the pump via the filter then distributed to 4 airbags which the Height is managed by a level sensor at each strut ..
My question is ,,, what other issue's can occur other than Pump Failing, blocked filter , leaking airbag , faulty level sensor
" Read somewhere about powder in the system " what is that ?
i know i am looking at this simplistically , But that is how i start my diagnosis.
cheers for any guidance in advance
keith
Post #599631 Thu Jun 04 2020 11:25am
There are three valve blocks that distribute air and control the level in each corner bag. One is adjacent the compressor and sends air to/from the reservoir and to the front/rear valve blocks. There are two axle blocks, one at the front, one at the rear. The front one is fixed to the rear of the front bumper on the right corner, the rear one is on the left rear suspension strut - you can see it through the wheel arch.
The valve blocks are connected to the centre valve block by pipes and then are connected to each air bag by a pipe. All air from the system is exhausted via the exhaust valve in the compressor - so if you lower the suspension, all four bags are exhausted via the valve blocks back through the compressor exhaust valve.
The valve blocks at each end also allow the air bags at their end to be connected e.g. if the front left wheel is pushed upwards, the front right wheel is pushed down by the air being pushed from the front left airbag. This mimics a solid axles when off road and helps with traction.
The height of each wheel is monitored by a sensor attached to each corner. These are calibrated so that the suspension control module knows where each is. If a sensor is changed, the system needs to be calibrated. The suspension control module is above the driver's feet on the front right A-pillar base. You can access it via the footwell.
If the air dryer in the compressor breaks down, it can cause the drying medium (white powder) to be pumped around the system. This then causes the valves to not be seated correctly and then they leak.
If the exhaust valve stops working, the system can't lower. A symptom is that when asked to lower, the vehicle will then go up to off road height. This is because the system knows it's asked to exhaust air to lower but doesn't see the lowering happen - it doesn't monitor the exhaust valve directly. If no lowering happens, the system assumes you are bottomed out on something so it raises the suspension to allow you to drive off the obstacle.
I think that's it in basic terms.
Simple! Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #599638 Thu Jun 04 2020 1:24pm
In terms of failures, leaking air bags are rare - they are robust items unlike the original system back in the P38 days.
Valve block issues do happen and is usually down to stuff on the seals.
The compressor exhaust valve isn't a serviceable item so if it fails, it's a new compressor. The air dryer is serviceable. The air inlet filter doesn't usually cause problems but it can do if it gets full of gunk.
Sensors do fail. One failing will throw an error light and give reduced performance. If two were to fail, the system would likely drop to the bump stops. This also happens if the calibration becomes corrupted. It's still driveable but it's not nice and is limited to low speed. 2012 SDV6 - it's missing a couple of cylinders
Post #599639 Thu Jun 04 2020 1:32pm
keith63
Thanks for the responses
i have recently replaced one of the levelling Arms on the OSR. and had to re-calibrate.
everything OK for a couple of Months
But now got amber triangle with codes C1A20-64 / U0421-68 / C1131-92
initially Bought a new End Plate for the Hitachi compressor ( i then realised i had an AMK )
so i bought a complete new unit from Bearmach ( excellent service , Inc Next Day delivery)
which i intend to replace tonight.
so my post was to cover all other angles , Just in case
thanks
keith
Post #599646 Thu Jun 04 2020 3:25pm
Can't find a U042168 but U042181 is invalid data from suspension control module. These comms errors can usually be ignored.
Quote:
C1A2064 Pressure Increase Too Slow When Filling Reservoir
Compressor fault
Reservoir pipe air leak
Reservoir air leak
Gallery pipe air leak
Intake filter
blocked/restricted
Intake pipe
blocked/restricted
Air suspension intake
silencer blocked/restricted
Corner valve stuck open
Pressure sensor fault
Quote:
C113192 Air Spring Air Supply
Unable to pressurize
gallery
Insufficient pressure from
compressor
Detached air pipe
Loose or burst air pipe
Reservoir valve block pipes
incorrectly installed
(unions reversed)
Post #599662 Thu Jun 04 2020 6:28pm
keith63
i got "U421-68 = Invalid data received from Ride level control Module.
will update shortly when new compressor is on
Post #599663 Thu Jun 04 2020 6:50pm
keith63
Replaced Compressor , all back to normal now
took on a test drive , initially created loads of errors , cleared those ( engine was cold though )
then on the same test Drive all ok , no Errors Generated.
Just Ready for Boris to open the Country then go on a long Journey to Properly test
Happy Days Very Happy
Post #599676 Thu Jun 04 2020 10:08pm
Drobe
Just for information on thread, I found my issue to be the Air receiver it had rusted out will pin holes on side nearest the subframe. Sorry about quality of pic but ensure you spray some washing up liquid around it.
Post #601189 Fri Jul 03 2020 8:15am
WexMan
Ireland 2006 Range Rover Sport TDV6 HSE Java Black
Folks, some stuff here I discovered in my recent suspension investigations and resolutions. Bit of a read but might help resolve issues as you trundle through the problems. I found a lot of different issues were resolved from simply changing Orings in valve blocks.
Interesting to see Drobe's issue was an air receiver.
https://www.rrsport.co.uk/gallery/albums/u...solved.pdf
Post #610027 Mon Feb 15 2021 8:38pm
WexMan - that's a heck of a guide you put together there. Excellent job. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #610057 Tue Feb 16 2021 10:45am
WexMan
Cheers, the funny thing is, same symptoms may result in a different root cause for others. Get the diagnostic tool out and break the problem down and try to corner that sneaky fu€&er Laughing
Post #610059 Tue Feb 16 2021 10:51am
Flyfisherman
That’s really helpful. Thanks Wexman
Post #610064 Tue Feb 16 2021 12:03pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
WexMan, excellent job mate Bow down That should be a sticky Thumbs Up Thumbs Up
Post #610398 Mon Feb 22 2021 9:22am
Devon Z
Great write up saved that to my reading list, thankfully don’t have any issues at the moment. Steve
1998 Volvo V70 R auto FWD, mothballed future project.
Post #610400 Mon Feb 22 2021 9:58am
WexMan
No bother folks. Hope it helps someone out of a jam.
Post #610402 Mon Feb 22 2021 11:13am
