Home > Technical > faults on suspension system |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
There are three valve blocks that distribute air and control the level in each corner bag. One is adjacent the compressor and sends air to/from the reservoir and to the front/rear valve blocks. There are two axle blocks, one at the front, one at the rear. The front one is fixed to the rear of the front bumper on the right corner, the rear one is on the left rear suspension strut - you can see it through the wheel arch.
Thu Jun 04 2020 1:24pm |
In terms of failures, leaking air bags are rare - they are robust items unlike the original system back in the P38 days.
Thu Jun 04 2020 1:32pm |
keith63 Member Since: 02 Sep 2019 Location: south staffs Posts: 73 |
Thanks for the responses
Thu Jun 04 2020 3:25pm |
Can't find a U042168 but U042181 is invalid data from suspension control module. These comms errors can usually be ignored.
2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Jun 04 2020 6:28pm |
i got "U421-68 = Invalid data received from Ride level control Module.
Thu Jun 04 2020 6:50pm |
Replaced Compressor , all back to normal now
Thu Jun 04 2020 10:08pm |
Drobe Member Since: 11 Jun 2020 Location: Warwickshire Posts: 9 |
Fri Jul 03 2020 8:15am |
WexMan Member Since: 15 Feb 2021 Location: Co. Wexford, Ireland. Posts: 14 |
Folks, some stuff here I discovered in my recent suspension investigations and resolutions. Bit of a read but might help resolve issues as you trundle through the problems. I found a lot of different issues were resolved from simply changing Orings in valve blocks.
Mon Feb 15 2021 8:38pm |
WexMan - that's a heck of a guide you put together there. Excellent job. 2012 SDV6 - it's missing a couple of cylinders
Tue Feb 16 2021 10:45am |
Cheers, the funny thing is, same symptoms may result in a different root cause for others. Get the diagnostic tool out and break the problem down and try to corner that sneaky fu€&er |
Tue Feb 16 2021 10:51am |
Flyfisherman Member Since: 12 Sep 2020 Location: Staffordshire Posts: 91 |
That’s really helpful. Thanks Wexman |
Tue Feb 16 2021 12:03pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
WexMan, excellent job mate That should be a sticky |
Mon Feb 22 2021 9:22am |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 313 |
Great write up saved that to my reading list, thankfully don’t have any issues at the moment. Steve
Mon Feb 22 2021 9:58am |
No bother folks. Hope it helps someone out of a jam. |
Mon Feb 22 2021 11:13am |
