Home > General (L494) > trickle charger recommendations?
TheGoodWillOut
car's been idle with lockdown so can anyone recommend a battery trickle charger as i'm getting battery low warnings now.
18 plate RRS sport 3.0 diesel with stop/start
thanks
Post #599208 Sat May 23 2020 8:15pm
knwatkins
The Ctek chargers are always well recommended. I have a MXS 5.0 and it does the job. Kev
Post #599209 Sat May 23 2020 8:32pm
Dave-t
I believe you need to do the start stop battery separately as well Joined the X5 45e club
1994 Defender 90 300 tdi
Post #599211 Sat May 23 2020 9:54pm
Lindab
Stop/start gets charged at the same time. +1 for Ctek MXS 5
Post #599212 Sat May 23 2020 10:19pm
If you go up to the Ctek MXS 7.0 or 10 you can also use it as a additional power source to the vehicle or a vehicle, if you remove the battery for any reason so not to lose any memory settings etc. not that there are a lot to lose on the Sport.
Post #599213 Sat May 23 2020 10:29pm
Dave-t
Reading back through a different thread, seems you might not have the second battery but a capacitor system instead Embarassed Embarassed
https://www.rrsport.co.uk/forum/topic56000.html Joined the X5 45e club
Post #599217 Sun May 24 2020 6:59am
Hodog16
United States
I’ve used a Noco Genius 5 and it’s a charger and maintainer. Attached it to the front posts under the hood (bonnet). I believe the batteries are AGM. Works great. 2016 SCV8 Dynamic - Firenze Red/Pimento
Post #599240 Sun May 24 2020 5:35pm
riverblanche
Hi,
I use a lidl smart charger Whistle via the tow socket
Martin has many plug options in "The Shop" for this route Thumbs Up
https://www.disco3.co.uk/shop/tow-electric...c-p45.html
or Tim's thread has been mentioned a number of times regarding a solar trickle charger have a search if you want that route
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #599244 Sun May 24 2020 6:41pm
TubaPlayer
I use a CTEK (either an MX5 or MX10) and it works great. 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #599290 Mon May 25 2020 8:27pm
Dave777
I use an MX7 with the tow socket charging plug mentioned above which works perfectly. Take the the little tab that holds the socket to the cable off and it pops off if you drive off with it attached. I know it works!! Very Happy MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys.
Post #599305 Tue May 26 2020 10:49am
Buckster
NOCO Genius chargers Wink Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #599314 Tue May 26 2020 6:18pm
TheGoodWillOut
I went with the Ctek MXS 5.0 - works a treat.
Post #599494 Mon Jun 01 2020 4:48pm
