![]() | Home > General (L494) > trickle charger recommendations? |
The Ctek chargers are always well recommended. I have a MXS 5.0 and it does the job. Kev
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
I believe you need to do the start stop battery separately as well Joined the X5 45e club
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 933 ![]() ![]() |
Stop/start gets charged at the same time. +1 for Ctek MXS 5 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5143 ![]() ![]() ![]() |
If you go up to the Ctek MXS 7.0 or 10 you can also use it as a additional power source to the vehicle or a vehicle, if you remove the battery for any reason so not to lose any memory settings etc. not that there are a lot to lose on the Sport.
Reading back through a different thread, seems you might not have the second battery but a capacitor system instead |
Hodog16 Member Since: 10 May 2015 Location: North Carolina Posts: 64 ![]() ![]() |
I’ve used a Noco Genius 5 and it’s a charger and maintainer. Attached it to the front posts under the hood (bonnet). I believe the batteries are AGM. Works great. 2016 SCV8 Dynamic - Firenze Red/Pimento |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
I use a CTEK (either an MX5 or MX10) and it works great. 2016 Black SDV8 Autobiography
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 ![]() ![]() |
I use an MX7 with the tow socket charging plug mentioned above which works perfectly. Take the the little tab that holds the socket to the cable off and it pops off if you drive off with it attached. I know it works!! |
NOCO Genius chargers |
TheGoodWillOut Member Since: 18 Oct 2018 Location: TheNorth Posts: 56 ![]() ![]() |
I went with the Ctek MXS 5.0 - works a treat. |
