Home > For Sale & Wanted > [For Sale] Front to rear roof rails.
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
Brand new in the box selling due to a change of plans, these are for 05-13 plate sports. Asking £75 including postage but collection would be preferred.
Post #597463 Tue Apr 07 2020 9:22am
Stevepd
Andy just check the fitting as I think (and I may be wrong Embarassed ) that those are for the facelifted RRS1, as I’m sure the prefacelifted has to have the solid rails. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #597466 Tue Apr 07 2020 10:46am
andyslandy
Fair point and I shall check, mine is a facelift but they lined up when I checked them. Thanks for the tip off though. Thumbs Up Thumbs Up
Post #597467 Tue Apr 07 2020 11:24am
Autobiography1969
I believe that the 2010-2013 have the holes already there and the gaps in the
strip are covered by individual covers that sit in the drainage gully,
2005-2009/10 don't have the same holes but it can still me made to fit with a 19mm
hole cutter.
&t=2s
Hope it helps you out with your sale ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #597477 Tue Apr 07 2020 3:04pm
andyslandy
Hi and thanks again guys, yes Autobiography you are right and i had to do that on my D3 when i fitted roof rails to that. If you have the later one like mine you have the pop out plastic rivets.
Post #597494 Tue Apr 07 2020 8:43pm
derekmines
Assuming that the fixing points are under the 3 round plastic covers spaced equally along the draining channel on the roof of my 59 plate facelift RRS then, if no one else has already taken them, I'd like to take these off your hands but would require the postage I'm afraid as you're aways away from me.
Post #597587 Thu Apr 09 2020 9:20pm
With genuine L/R rails you still have to increase the size of the hole to 19mm even after removing the plastic blanking plugs on 2010-2013 cars. The ones illustrated for sale do not look like genuine L/R so may be different.
Post #597591 Thu Apr 09 2020 11:55pm
andyslandy
Not sur if this is the proper way to do it but the item is now SOLD, thanks for the interest and regards Andy. Thumbs Up [/s][/code]
Post #597602 Fri Apr 10 2020 1:21pm
derekmines
Confirmed that the fitting kit that came with these contained the correct size fixings.
Didn't stop me having to drill out the plastic caps from the car though, they were well and truly seized.
All done now though, they're a nice fit and feel plenty solid enough.
Post #598506 Mon May 04 2020 9:15am
andyslandy
Pleased to hear Derek, these plastic poppers cause real grief and i wonder if they melt into place with the sun on them (well so called sun).
Post #598513 Mon May 04 2020 10:07am
derekmines
It actually looked as though water had got into the screw threads that they protect and surface corrosion on the threading of the hole had bonded to the plastic poppers, whilst the sun on the top cap had weakened it, causing 5 of the 6 to snap off, leaving my drill some work to do!
Post #598515 Mon May 04 2020 11:11am
