![]() | Home > For Sale & Wanted > [For Sale] Front to rear roof rails. |
andyslandy Member Since: 20 Oct 2019 Location: Chesterfield Posts: 142 ![]() ![]() ![]() |
Fair point and I shall check, mine is a facelift but they lined up when I checked them. Thanks for the tip off though. |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 477 ![]() ![]() |
I believe that the 2010-2013 have the holes already there and the gaps in the
Hi and thanks again guys, yes Autobiography you are right and i had to do that on my D3 when i fitted roof rails to that. If you have the later one like mine you have the pop out plastic rivets. |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 ![]() ![]() ![]() |
Assuming that the fixing points are under the 3 round plastic covers spaced equally along the draining channel on the roof of my 59 plate facelift RRS then, if no one else has already taken them, I'd like to take these off your hands but would require the postage I'm afraid as you're aways away from me. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5104 ![]() ![]() ![]() |
With genuine L/R rails you still have to increase the size of the hole to 19mm even after removing the plastic blanking plugs on 2010-2013 cars. The ones illustrated for sale do not look like genuine L/R so may be different. Cheers Col |
Not sur if this is the proper way to do it but the item is now SOLD, thanks for the interest and regards Andy. |
Confirmed that the fitting kit that came with these contained the correct size fixings. Didn't stop me having to drill out the plastic caps from the car though, they were well and truly seized. All done now though, they're a nice fit and feel plenty solid enough. |
Pleased to hear Derek, these plastic poppers cause real grief and i wonder if they melt into place with the sun on them (well so called sun). |
It actually looked as though water had got into the screw threads that they protect and surface corrosion on the threading of the hole had bonded to the plastic poppers, whilst the sun on the top cap had weakened it, causing 5 of the 6 to snap off, leaving my drill some work to do! |
