Home > General > T.P.M.
Best Yet
T.P.M.
Are tyre pressure valves & monitoring sensors available as a single unit or are the only sold in sets of 4 - need one for my spare wheel
Post #595380 Sat Feb 22 2020 4:42pm
Yes, you can buy them separately. If I remember correctly if you fit one to the spare it may need to be activated in the CCF files so the car knows the spare has one as well as I believe the system will periodically check it, assuming you have a full size spare as sure they cannot be fitted to space savers.
Found this bit as well so make sure you take the number of the sensor before fitting it, have a feeling it's a 8 digit number.
If the tire pressure sensors fitted to the running wheels (not the spare) are changed, the CJB can learn the new sensor
identifications automatically. The learn function requires no manual intervention by the driver.
If a new sensor is fitted to the spare tire it must have its identification code programmed into the CJB using a Land Rover
approved diagnostic system.
Post #595410 Sat Feb 22 2020 10:10pm
Tim in Scotland
There are two systems - pre and post legal requirement for TPMS - so check which you need , take your VIN and model year details to the supplier. The earlier system was a very basic system and was an option, just showed you had a tyre that was below pressure, the newer system shows individual tyre pressures on the dash and what the pressure should be. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #595435 Sun Feb 23 2020 11:08am
Best Yet
Thanks for info it is a post legal requirement valve that is needed.
Post #595446 Sun Feb 23 2020 3:32pm
Tyrefitter
Doesn’t need one in spare,but if car is registered after 1st of January 2012 system needs to work as it should in all 4 wheels.
Taken from the MoT manual
Tyre pressure monitoring system (TPMS)
The inspection of the tyre pressure monitoring system (TPMS) is for M1 vehicles first used on or after 1 January 2012.
The TPMS warning lamp (see diagram 3) can operate in many ways depending on the vehicle type. You must only reject vehicles if it’s clear that the lamp indicates a system malfunction and not simply indicating that one or more of the tyre pressures is low.
Diagram 3. Example of a TPMS warning lamp
 Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #595447 Sun Feb 23 2020 4:14pm
