![]() | Home > General > T.P.M. |
| Best Yet Member Since: 02 Feb 2018 Location: W.MIDS Posts: 42
Are tyre pressure valves & monitoring sensors available as a single unit or are the only sold in sets of 4 - need one for my spare wheel |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
Yes, you can buy them separately. If I remember correctly if you fit one to the spare it may need to be activated in the CCF files so the car knows the spare has one as well as I believe the system will periodically check it, assuming you have a full size spare as sure they cannot be fitted to space savers.
Thanks for info it is a post legal requirement valve that is needed. |
| Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677
Doesn’t need one in spare,but if car is registered after 1st of January 2012 system needs to work as it should in all 4 wheels.
| All times are GMT |
