Home > Maintenance & Modifications > Replacing air struts |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
If there's nothing wrong with your struts then they don't need replacing. Same with the height sensors.
Fri Feb 21 2020 8:48pm |
Also, have a look at your previous post. You have some useful answers..
Fri Feb 21 2020 8:52pm |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
You're aware that all air suspenion is active right ? don't confuse it with active damping that bit is a yes or no but air suspension that constantly adjusts is basically what air suspension is in its most basic form 2012 SDV6 HSE (technically its hers) 2000 D2 TD5 - definitely mine 2005 D3 V8 Metalian Camper trailer for adventures |
Fri Feb 21 2020 10:18pm |
