![]() | Home > Maintenance & Modifications > 2011 Range Rover Sport air strut life span |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
Can’t really help on how long they may last, but have a read of this regards the cost of replacements, they are available for a lot less than you’ve found.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9151 ![]() ![]() ![]() |
It's a tricky question. My previous RRS had 175k miles on the original struts when I sold it. Were they knackered? Probably. Did it ride badly? No.
I think it all depends on how the car has been used over its life. If it has been sat on the motorway then they may be alright, if its been used on the school run over speed bumps or extensive off road use for 100k, you can safely say they need replacing.
ryan_holton Member Since: 07 Jul 2019 Location: Bridgend Posts: 26 ![]() ![]() |
The air struts I've been quoting are from Euro Car Parts: https://www.eurocarparts.com/search/626670481
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
My car is 12 years old and is still fine and we have worse roads than you do - dont go looking for issues that are not there. If there are symptoms well that is different.
Don't bother with ECP for those kinds of parts. You are much better off going to a specialist LR part supplier. If you have an electrical connector on your struts, you have the adaptive damping and the part numbers are: Fronts: LR052867 (LH & RH) Rears: LR032651 (LH) and LR032652 (RH) If you do not have an electrical connector on your strut, you do not have the adaptive damping and the part numbers are: Fronts: LR016415 (LH & RH) Rears: LR016419 (LH & RH) Have a Google around. As I mentioned, I found the John Craddock to be the cheapest when I bought mine. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
The site sponsor Advanced Factors supply the genuine OEM(LR) ones for a very reasonable cost. I'm getting some at the end of the month.
