Home > Technical > Folding mirrors
TIG1591
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Zermatt Silver
Folding mirrors
2010 TDV6 SE. Should the mirrors fold in /out using buttons on door and automatically using keyfob on lock/unlock.
Mine dont/won't any ideas could it be just a fuse. They dip/turn using buttons as normal!
Post #594276 Mon Feb 03 2020 10:11pm
Powerfold mirrors were a option on a SE so you may not have them fitted.
Post #594280 Mon Feb 03 2020 10:31pm
Not in Great Britain
Post #594284 Mon Feb 03 2020 11:04pm
They were a option on the SE in the UK.
Post #594285 Mon Feb 03 2020 11:20pm
TIG1591
Thanks Col as I expected😏
Post #594288 Mon Feb 03 2020 11:46pm
As they were a option you may be able to retro fit and activate in the CCF files if you wanted to, but would need to check if the wiring is there in the door first, rather than buying mirrors then trying.
Post #594289 Mon Feb 03 2020 11:59pm
Odd I thought the early ones 2005 it were standard across the range.
I recall it cus I was surprised.
Post #594290 Tue Feb 04 2020 12:12am
Virtually everything now is a option which used to be standard so L/R can charge even more for their over priced products and gimmicks.
Post #594292 Tue Feb 04 2020 12:19am
Brit Plumber
I think the powerfold is only available with memory seat perhaps because of the looms having extra wiring for the mirror memory and dip in reverse. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #594366 Wed Feb 05 2020 12:11am
Generaly I think if something is only available with something else it will say in the price list (only available with so and so pack) or something to that effect, however the powerfold mirrors are listed as a option on their own in the old 10-11 pricelist, so the wiring may well be there.
Post #594369 Wed Feb 05 2020 4:12am
Brit Plumber
I think you’re right Col, it appears it’s only a little wire from the door module to the mirror, the power fold motor and a CCF edit. Amazing why it was never standard equipment considering the motors won’t be expensive to buy (although LR probably want to charge triple the cost).
Post #594423 Wed Feb 05 2020 11:39pm
70 mph. That looks a mistake.
Usually it’s closer to 7mph
Post #594443 Thu Feb 06 2020 12:49pm
Yeah, say's stationary or less than 20km/h or 12mph in the owners handbook.
Post #594460 Thu Feb 06 2020 9:08pm
