![]() | Home > Technical > Folding mirrors |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5097 ![]() ![]() ![]() |
Powerfold mirrors were a option on a SE so you may not have them fitted.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5098 ![]() ![]() ![]() |
Not in Great Britain |
They were a option on the SE in the UK.
TIG1591 Member Since: 02 Feb 2020 Location: Derbyshire Posts: 3 ![]() ![]() ![]() |
Thanks Col as I expected😏 |
As they were a option you may be able to retro fit and activate in the CCF files if you wanted to, but would need to check if the wiring is there in the door first, rather than buying mirrors then trying.
Odd I thought the early ones 2005 it were standard across the range.
Virtually everything now is a option which used to be standard so L/R can charge even more for their over priced products and gimmicks.
I think the powerfold is only available with memory seat perhaps because of the looms having extra wiring for the mirror memory and dip in reverse. 2019 5.0 SC SVA (Current)
Generaly I think if something is only available with something else it will say in the price list (only available with so and so pack) or something to that effect, however the powerfold mirrors are listed as a option on their own in the old 10-11 pricelist, so the wiring may well be there.
I think you’re right Col, it appears it’s only a little wire from the door module to the mirror, the power fold motor and a CCF edit. Amazing why it was never standard equipment considering the motors won’t be expensive to buy (although LR probably want to charge triple the cost).
70 mph. That looks a mistake.
Yeah, say's stationary or less than 20km/h or 12mph in the owners handbook.
