![]() | Home > Faults & Fixes > No power below 2500rpm |
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 ![]() ![]() ![]() |
Wild guess, but could be EGR valves.......
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1207 ![]() ![]() ![]() |
has it had a turbo recon job in the past?
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Timo Member Since: 15 May 2016 Location: Lancashire Posts: 36 ![]() ![]() |
It’s a 2.7, it also has an engine warning light on.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
The intercooler hoses delaminate/split and restrict airflow. Fairly cheap and easy to replace. I would consider that first. Many owners replace them with silicone hoses for longevity. I think there are 3, but it's usually the big one at the front and top of the engine. |
Dennis V Baldwin Member Since: 05 May 2015 Location: East Grinstead Posts: 13 ![]() ![]() ![]() |
if it smokes like a gooden at start up its EGRs!
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
I had that last year, lucky it was just the long turbo hose cheap and easily to change. |
