Home > Technical > TDV8 3.6 RRS 2008 P0191-23 WONT START NO FUEL PRESSURE HELP |
Tobias275 Member Since: 04 Jan 2020 Location: kent Posts: 12 |
Also is there a way of raising the suspension without the engine running ? |
Sat Jan 04 2020 7:02pm |
This is what the code brings up so try fuses to start
Sun Jan 05 2020 9:27am |
the fuel fuse under the bonnet is ok power coming in and power coming out
Sun Jan 05 2020 11:12am |
Not 100% but with ignition on is there any pressure at valve or can you here pump start when key first turned on |
Sun Jan 05 2020 11:22am |
theres no pressure at the Schrader valve when initial ignition or whilst cranking, also i cannot hear the pump under the seat |
Sun Jan 05 2020 11:30am |
Start looking at the pump then and power supply to it |
Sun Jan 05 2020 11:39am |
if the pressure sensor is faulty would that stop the LPFP from firing up?
Sun Jan 05 2020 11:48am |
You never mentioned the injectors before |
Sun Jan 05 2020 11:54am |
apologies, i edited the post earlier to put the fuller picture as i realised people need all the info |
Sun Jan 05 2020 12:30pm |
what else would you advise i need to check? |
Sun Jan 05 2020 4:34pm |
make sure you have everything you took apart back in its right place as you say it was ok prior to you removing the injectors |
Sun Jan 05 2020 4:39pm |
checked everything at the front is all connected, power to both sides of the fuse and relay working. no noise from the tank area on initial ignition so went to check the continuity at the pump.
Tue Jan 07 2020 11:07am |
Have a look at this may help
Tue Jan 07 2020 11:46am |
thanks for the link, i checked myn and the tailgate door was programmed to open.
Tue Jan 07 2020 7:46pm |
