Home > Technical > TDV8 3.6 RRS 2008 P0191-23 WONT START NO FUEL PRESSURE HELP
Tobias275
England 2008 Range Rover Sport TDV8 Autobiography Zermatt Silver
ive just put a new battery on my RRS and the 400a mega fuse had blown which can only be due to cranking to many times or boost pack/jumpleads in my opinion.
ive cleared all the fault codes and now it spins over fine but will not fire.
the only fault code is showing P0191-23 ?
now there is no pressure at the schrader valve, ive put more diesel in as it is parked on a slope and the guage was showing between empty and 1/4 tank.
has anyone got any suggestions of where to start please
Post #592773 Sat Jan 04 2020 7:56pm
Tobias275
TDV8 3.6 RRS 2008 SUSPENSION
Also is there a way of raising the suspension without the engine running ?
Post #592775 Sat Jan 04 2020 8:02pm
geoffsnook
This is what the code brings up so try fuses to start Thumbs Up
Faulty fuel pressure sensor
Faulty fuel pressure sensor circuit
Faulty fuel pressure sensor connector
Faulty fuel pressure regulator
Post #592814 Sun Jan 05 2020 10:27am
Tobias275
the fuel fuse under the bonnet is ok power coming in and power coming out
how do i check if the pressure sensor is faulty or not without buying a new one?
Also, Ive just removed and replaced all 8 injectors to do a compression test. prior to this it started fine (well okish hence removing the injectors).
There was no issue with the fuel pressure at the Schrader valve or injectors prior
thanks in advance
Post #592819 Sun Jan 05 2020 12:12pm
geoffsnook
Not 100% but with ignition on is there any pressure at valve or can you here pump start when key first turned on
Post #592820 Sun Jan 05 2020 12:22pm
Tobias275
theres no pressure at the Schrader valve when initial ignition or whilst cranking, also i cannot hear the pump under the seat
Post #592822 Sun Jan 05 2020 12:30pm
geoffsnook
Start looking at the pump then and power supply to it Thumbs Up
Post #592824 Sun Jan 05 2020 12:39pm
Tobias275
if the pressure sensor is faulty would that stop the LPFP from firing up?
ive also read that the Fuel Filter can cause this problem?
it just seems strange to suddenly stop after only removing and replacing the injectors
Post #592827 Sun Jan 05 2020 12:48pm
geoffsnook
You never mentioned the injectors before Question
Post #592829 Sun Jan 05 2020 12:54pm
Tobias275
apologies, i edited the post earlier to put the fuller picture as i realised people need all the info
Post #592833 Sun Jan 05 2020 1:30pm
Tobias275
what else would you advise i need to check?
Post #592851 Sun Jan 05 2020 5:34pm
geoffsnook
make sure you have everything you took apart back in its right place as you say it was ok prior to you removing the injectors Thumbs Up
Post #592853 Sun Jan 05 2020 5:39pm
Tobias275
checked everything at the front is all connected, power to both sides of the fuse and relay working. no noise from the tank area on initial ignition so went to check the continuity at the pump.
so, after taking the back seat out i now know that the tank has to be dropped from underneath.
its parked on my drive which is about 35-40 degree slope and on its bump stops, does anyone know how i can raise the suspension without doing any damage ?
Post #592956 Tue Jan 07 2020 12:07pm
geoffsnook
Have a look at this may help Thumbs Up
https://www.disco3.co.uk/forum/manually-ra...automobile
Post #592957 Tue Jan 07 2020 12:46pm
Tobias275
thanks for the link, i checked myn and the tailgate door was programmed to open.
i tried following the steps in the video but it never worked due to the engine not starting i think.
helped my pal with a disco 3 Thumbs Up
Post #592982 Tue Jan 07 2020 8:46pm
