Home > Technical > Trim clips
SomersetRRS
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Trim clips
The bottom door trim on my 2008 RRS was loose when I got it so I purchases some new yellow/white trim clips.
However, they still seem to pop out every now and again. I was thinking of gluing the yellow bit into the door somehow.
Anyone else had this problem/have a solution?
Thanks.
Post #592624 Thu Jan 02 2020 11:01am
Dave B
Had to get some myself recently, was advised the 'cheap' ones on ebay wouldn't be any good, got mine from local stealers and no problems. Did you buy genuine LR? 2010 3.6 TDV8 HSE (Gone)
Post #592625 Thu Jan 02 2020 11:06am
Could always try the one piece black one's they normally use on the ends of the front door trim DYC500110.
Post #592626 Thu Jan 02 2020 11:07am
SomersetRRS
I must admit I didn't buy the LR ones so maybe that's the issue. The ones I've got hold for a while and then give up and pull out in one piece (white and yellow bits joined together.
Maybe I need to go to the stealer.
Post #592627 Thu Jan 02 2020 11:11am
SomersetRRS
Col wrote:
Could always try the one piece black one's.
I've not seen the one piece clips. Are they easy to find?
Post #592628 Thu Jan 02 2020 11:12am
Dave B
Also, the clip at either end is different and black in colour, to those inbetween which are yellow/white. 2010 3.6 TDV8 HSE (Gone)
Post #592629 Thu Jan 02 2020 11:15am
DYC500110
Post #592630 Thu Jan 02 2020 11:15am
SomersetRRS
Thanks, both. I'll talk to the stealer and see what they suggest - either all black or a mix of the two types as per OEM install.
Post #592632 Thu Jan 02 2020 11:25am
Post #592633 Thu Jan 02 2020 11:26am
