![]() | Home > Technical > Trim clips |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 432 ![]() ![]() ![]() |
Had to get some myself recently, was advised the 'cheap' ones on ebay wouldn't be any good, got mine from local stealers and no problems. Did you buy genuine LR? 2010 3.6 TDV8 HSE (Gone)
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5112 ![]() ![]() ![]() |
Could always try the one piece black one's they normally use on the ends of the front door trim DYC500110.
SomersetRRS Member Since: 18 Nov 2019 Location: Somerset Posts: 65 ![]() ![]() ![]() |
I must admit I didn't buy the LR ones so maybe that's the issue. The ones I've got hold for a while and then give up and pull out in one piece (white and yellow bits joined together. Maybe I need to go to the stealer. |
I've not seen the one piece clips. Are they easy to find? |
Also, the clip at either end is different and black in colour, to those inbetween which are yellow/white. 2010 3.6 TDV8 HSE (Gone)
DYC500110
Thanks, both. I'll talk to the stealer and see what they suggest - either all black or a mix of the two types as per OEM install. |
