Home > Technical > Hissssing...then front suspension now dropped. RRS tdv8
Jampot1979
So today while sitting at traffic lights, there was a sudden loud hissssing of air as if taking air out of a tyre, which is what I thought happened. I got out of car and checked around and didn't notice anything. So continued to drive and after say a minute car was on the ground..... With warning on dash not to exceed 30mph. I managed to get to a side road and called a recovery truck. While waiting I did restart car and moved it to a better position ready for recovery truck. The rear suspension seemed to raise to normal height, but front stayed low.
So hoping it's a simple fix....has this ever happened to any of you guys ?
Post #590461 Fri Nov 15 2019 6:12pm
knwatkins
If it's localised to the front, it will be something ahead of the front valve block which is situated inside the offside front wheel arch. It could be either:
Front valve block issue
Front air-spring issue
Airline issue between front valve block and the front strut Kev
Post #590468 Fri Nov 15 2019 8:26pm
Jampot1979
It's fixed!
Basically the pre-heater exhaust has a small hole in it, which was leaking hot gases onto the plastic air suspension pipe and melted a hole in it. Rolling Eyes
Post #590697 Wed Nov 20 2019 7:39pm
knwatkins
Great news Thumbs Up Kev
Post #590704 Wed Nov 20 2019 9:52pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Quote:
It's fixed!
Ooo... Interesting, might be worth checking that this isn't an upcoming issue on mine Shocked
Post #590873 Sat Nov 23 2019 4:09pm
Eaters
And mine! I use my pre-heater a lot. Thanks for the post Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #590913 Sun Nov 24 2019 10:50am
Jampot1979
Couldn't believe how rotten the pre heater exhaust was. Completely gone on the small flexi section. Purchased a new exhaust for £23. Part No: JEZ500050.
The air pipe is located right next to it so its worth checking. Just unclip the arch liner and its right in front of you. Annoying I had to purchase a new airline (£90) plus labour to fit it.
Worth checking guys....
Guess they are getting to that age where bits like this will become the next common issue Mad
Post #591417 Tue Dec 03 2019 4:23pm
