Home > Maintenance & Modifications > 2010 TDV8 - AGM or standard battery?
aaronjb
Quick question, does anyone know if a 2010 TDV8 (no stop-start) would have an AGM battery or standard lead acid?
Currently has an AGM but I suspect it's on its last legs.. and I'm not sure a non stop-start would have originally had an AGM battery. Unless it's like the BMW and can be coded either way? 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #590192 Sun Nov 10 2019 11:21am
Disco_Mikey
It's not a stop start model, but all 2010>models were smart charge, so require an AGM Thumbs Up
Post #590193 Sun Nov 10 2019 11:42am
gogsy1956
Mine has standard lead acid,, when i replaced it a couple of years ago I put the same type back in. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #590194 Sun Nov 10 2019 11:43am
As normal L/R confuse things, according to the parts list if I read it correctly, RRS1 Petrol Variants only ever had wet cell batteries fitted, 3.0 and 3.6 up to VIN No. BA716316 had wet batteries, BA716317 on had AGM's fitted. My S/C certainly never came with a AGM battery and that's a MY13 car, although I have fitted one now and nothing needed to be coded when fitted.
Post #590196 Sun Nov 10 2019 11:58am
aaronjb
Thanks all - sounds like it's meant to be AGM then, although maybe not based on gogsy and my VIN based on what Col says.. ahh, confused Smile
Tayna reckon AGM, and that's what's there so I guess it's the expensive option!
Battery voltage is dropping to 9v when cranking though, so it's definitely past its best. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #590235 Sun Nov 10 2019 10:24pm
This is what I fitted to mine with no problems, it is the equiavilent of the UK 019, although Tayna say UK 020 fit's, however I personaly couldn't get the 020 in as it's 40mm longer than the original 019 and would have had to push a lot of wiring out the way and force it in and not worth the effort for slightly more AH/Power.
https://www.tayna.co.uk/car-batteries/varta/g14/
Post #590239 Sun Nov 10 2019 10:38pm
Autobiography1969
This is the one I have lined up when I get around to changing mine
https://www.halfords.com/motoring/bulbs-bl...-guarantee
Currently £143
Fitting available for £15 more..
5 year warranty... ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Last edited by Autobiography1969 on Sun Nov 10 2019 11:06pm. Edited 1 time in total
Post #590241 Sun Nov 10 2019 10:43pm
I previously had Two Yuasa batteries fail in quick succession so only ever fit Varta now as I think the original L/R battery was a re-branded Varta, may have been just unlucky though with the Yuasa.
Post #590242 Sun Nov 10 2019 10:47pm
Currently £143
5 year warranty...
Halfords may not change it for you. They have a list of "suitable vehicles" and the RRS isn't on it. Or at least it wasn't when I changed the battery in my TDV8 a couple of years ago. Check before buying.
I fitted the Yuasa HASB019 Silver myself. 2012 SDV6 - it's missing a couple of cylinders
Post #590246 Mon Nov 11 2019 8:24am
Autobiography1969
I am sure either I can fit it or a local garage will help me out..
But thanks for the heads up,, will possibly save me getting annoyed
when Halfords let me down,, ===========================================
Post #590270 Mon Nov 11 2019 9:06pm
knwatkins
Currently £143
5 year warranty...
I bought one of these last week. £95 with a trade card so worth signing up Wink
 Kev
Post #590272 Mon Nov 11 2019 9:24pm
aaronjb
Battery is on its way to me now Thumbs Up anyone know if the smart-charge cars need the battery coding (or "registering" to use BMW parlance) for the charge profile to be correct on the new battery?
BTW, Kev - do they let anyone sign up for a trade card these days? Last time I looked (waaay back when) you had to have proof of being in the trade (payslips, etc).. I never tried blagging my way into one.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #590291 Tue Nov 12 2019 9:30am
You will not need any codes when swapping battery, if I remember correctly all you will have to do is reset the date as it defaults to 2009 and reset the electric windows "one touch operation" easy enough, also the sunroof if you have one. As far as the BMS is concerned reset it if you have a diag. tool, if not apparently they do periodically do a self calibration test so not a real issue, I think I would just make sure the new battery is fully charged before fitting it. I replaced my Lead Acid with a AGM and never changed any setting on the car to say it had been changed to AGM, different rating or anything else, that was three years ago and have never had any battery issues at all.
Post #590293 Tue Nov 12 2019 9:51am
knwatkins
You just need to show your proof of trade. A simple letterhead or business card will suffice Wink
See 'what proof of trade do I need?' here for more info... https://www.halfords.com/advice/customer-services/trade-card Kev
Post #590333 Tue Nov 12 2019 8:11pm
aaronjb
/me quietly places an order with VistaPrint for some business cards Whistle
They can go with the service stamp I have in the garage Mr. Green 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #590358 Wed Nov 13 2019 9:01am
