![]() | Home > General > TPMS |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
behind the headlights
McFarTech Member Since: 13 Sep 2019 Location: Kent Posts: 126 ![]() ![]() ![]() |
Ok. Will take a look at the weekend. Thanks mate ===========================================
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
Should be a plug up in the roof panel under the front interior light consul, can't remember what colour the plug is though. The TPMS system on the RRS1 is pretty useless, just tells you which wheel is down on pressure and that has to drop to around 25psi before it registers, that's it nothing else doesn't even show actual pressures. Did intend to change mine for a superior aftermarket one but never got round to it.
I’m happy to look at an after market system. Any suggestions? ===========================================
Violet plug by the looks of it.
Thanks mate. Yeah that box in the car look hideous. Don’t mind the valve caps but yeah could not have that box in the Range. Need something a little more factory look or smaller device in side the car. ===========================================
If I read the Steelmate advertising correctly you can integrate it into the headunit/screen, but not to sure whether can do it with the Sport. I might well buy one and see.
Where you looking at buying from? If not mega expensive I might give it a go as well. ===========================================
Could try here in the UK look to be around £160.00 so not the end of the world if doesn't work. I will proably be lookin at OZ personally, could pick one up on one of my trips over there.
Might give it a blast. I’m guessing the Range has a rca connection somewhere to plug in to? ===========================================
I was wondering if it was possible to use the ones in the rear aux panel under the flap between the front seats if they are also inputs, to see if would at least work, not a audio/visual engineer though. |
Interesting. Will add this little mod to my list of items. ===========================================
