Home > General > TPMS
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
TPMS
Guys.
Where can I check on the Range if I have the wiring for the TPMS system?
Craig ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #590033 Thu Nov 07 2019 5:34pm
behind the headlights
small grey connectors maybe
Post #590046 Thu Nov 07 2019 8:26pm
McFarTech
Ok. Will take a look at the weekend. Thanks mate ===========================================
Post #590049 Thu Nov 07 2019 8:40pm
Should be a plug up in the roof panel under the front interior light consul, can't remember what colour the plug is though. The TPMS system on the RRS1 is pretty useless, just tells you which wheel is down on pressure and that has to drop to around 25psi before it registers, that's it nothing else doesn't even show actual pressures. Did intend to change mine for a superior aftermarket one but never got round to it.
Post #590052 Thu Nov 07 2019 9:15pm
McFarTech
I’m happy to look at an after market system. Any suggestions? ===========================================
Post #590053 Thu Nov 07 2019 9:20pm
Violet plug by the looks of it.
Had one of these on my previous sport, https://www.amazon.co.uk/TyrePal-Pressure-...amp;sr=8-4 not the prettiest but worked very well, just that the wheel sensors are external and quite large. why I was looking at the Steelmate as sensors are internal I believe.
Post #590055 Thu Nov 07 2019 9:29pm
McFarTech
Thanks mate. Yeah that box in the car look hideous. Don’t mind the valve caps but yeah could not have that box in the Range. Need something a little more factory look or smaller device in side the car. ===========================================
Post #590056 Thu Nov 07 2019 9:40pm
If I read the Steelmate advertising correctly you can integrate it into the headunit/screen, but not to sure whether can do it with the Sport. I might well buy one and see.
Post #590057 Thu Nov 07 2019 10:00pm
McFarTech
Where you looking at buying from? If not mega expensive I might give it a go as well. ===========================================
Post #590059 Thu Nov 07 2019 10:12pm
Could try here in the UK look to be around £160.00 so not the end of the world if doesn't work. I will proably be lookin at OZ personally, could pick one up on one of my trips over there.
https://www.steel-mate.co.uk/acatalog/Prof...stems.html
Post #590060 Thu Nov 07 2019 10:22pm
McFarTech
Might give it a blast. I’m guessing the Range has a rca connection somewhere to plug in to? ===========================================
Post #590061 Thu Nov 07 2019 10:26pm
I was wondering if it was possible to use the ones in the rear aux panel under the flap between the front seats if they are also inputs, to see if would at least work, not a audio/visual engineer though. Laughing
Post #590065 Thu Nov 07 2019 10:48pm
McFarTech
Interesting. Will add this little mod to my list of items. ===========================================
Post #590066 Thu Nov 07 2019 10:54pm
