Home > In Car Electronics > No sound from audio.
Micky Mojo
Hi hope someone can point me in the right direction, I've tried searching google but I can't find anything that matches my exact problem.
I've had my RRS TDV8 2008 125,000 miles for a year and haven't had much luck with it.
Last January during a very cold spell I went out to the car and it wouldn't start. I ended up having to have the body control unit and ECU replaced but when I got the car back the stereo wouldn't produce any sound. The garage that did the work wouldn't accept any responsibility for this issue and said it isn't related to the ECU replacement. The CD player and radio appear to work as does the satnav just without any sound. The car does have Harmon Kardon signs on the doors.
Hope somebody can help, listening to the radio on my phone isn't the same. Thanks in advance.
Post #589437 Tue Oct 29 2019 5:29pm
Brit Plumber
This sounds like an AMP issue, check the fuse for the Amp but I suspect it will be on the same circuit and fuze as the screen etc. So probably ok. Can you do a check of the voltage at the Amp connector? Do you have an IID tool? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #589468 Tue Oct 29 2019 11:53pm
Micky Mojo
Hi mate thanks for the reply. I don't have an IID tool.
I've checked these two fuses and they look ok.
There's also this one but I don't know how I would check it.
Post #589481 Wed Oct 30 2019 10:15am
Micky Mojo
I managed to take it apart but it looks ok.
Post #589482 Wed Oct 30 2019 10:19am
Brit Plumber
I didn’t think it would be fuses, that would be to easy.
Can you check for power to the amp using a fluke or similar? If you get power at the amp then it could be either the amp has given up (does happen when water gets to it) or more likely a config issue seeing as you’ve had the BCM replaced. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #589485 Wed Oct 30 2019 12:16pm
Micky Mojo
The car is bone dry inside (no sunroof). I have a battery tester, could I use that? Which wire do I test?
Post #589486 Wed Oct 30 2019 12:18pm
Ljdiscovery
United States 2006 Range Rover Sport 4.4 V8 HSE Giverney Green
HI, any update on your lack of sound issue? I have a similar problem. thanks Phil
Post #597916 Mon Apr 20 2020 12:06am
