Home > In Car Electronics > No sound from audio. |
This sounds like an AMP issue, check the fuse for the Amp but I suspect it will be on the same circuit and fuze as the screen etc. So probably ok. Can you do a check of the voltage at the Amp connector? Do you have an IID tool? 2012 5.0 SC AB
Tue Oct 29 2019 11:53pm |
Micky Mojo Member Since: 10 Dec 2018 Location: North East Posts: 4 |
Hi mate thanks for the reply. I don't have an IID tool.
Wed Oct 30 2019 10:15am |
I managed to take it apart but it looks ok.
Wed Oct 30 2019 10:19am |
I didn’t think it would be fuses, that would be to easy.
Wed Oct 30 2019 12:16pm |
The car is bone dry inside (no sunroof). I have a battery tester, could I use that? Which wire do I test? |
Wed Oct 30 2019 12:18pm |
Ljdiscovery Member Since: 30 Apr 2016 Location: La Jolla, california Posts: 42 |
HI, any update on your lack of sound issue? I have a similar problem. thanks Phil |
Mon Apr 20 2020 12:06am |
