Home > General > Drivers door mirror 'wandering' |
It’s a commonish fault that happens to some but not all. Could be a bad memory motor. 2012 5.0 SC AB
Tue Oct 29 2019 7:51pm |
jordan781 Member Since: 26 Sep 2019 Location: Varna Posts: 5 |
Hi, I found the same problem with my car today, I disassembled the entire mechanism, but I found that the two engines located inside do not remember their positions and lose sync. Please tell me how you turned this feature off? |
Mon Nov 18 2019 8:38pm |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 |
If you go to the internal settings on the dashboard you can disable the reversing mirrors in there. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Mon Nov 18 2019 8:52pm |
Thanks Did you find out what caused this problem? |
Mon Nov 18 2019 9:13pm |
I'm going to get a memory motor secondhand and try that but it is a job I will get round to when I have the time. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Wed Nov 20 2019 6:22pm |
