![]() | Home > General > Drivers door mirror 'wandering' |
| Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849
It’s a commonish fault that happens to some but not all. Could be a bad memory motor. 2019 5.0 SC SVA (Current)
| jordan781 Member Since: 26 Sep 2019 Location: Varna Posts: 5
Hi, I found the same problem with my car today, I disassembled the entire mechanism, but I found that the two engines located inside do not remember their positions and lose sync. Please tell me how you turned this feature off? |
| Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155
If you go to the internal settings on the dashboard you can disable the reversing mirrors in there. |
Thanks |
I'm going to get a memory motor secondhand and try that but it is a job I will get round to when I have the time. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
