Home > General > LED Wing Mirrors Retro fit
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Guys
Is there a retrofit or another year RRSport that has LED wing mirrors for the turn signals that I can fit?
Would really like to have this feature back on my car.
Craig ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #589300 Sat Oct 26 2019 8:44pm
Late Disco 4
Post #589301 Sat Oct 26 2019 9:04pm
McFarTech
Thats exactly what I am looking for.
What year Disco?
Post #589302 Sat Oct 26 2019 9:05pm
2014 on, could use RRS2 mirrors but still need Disco mountings that bolt to door. When I did mine I bought brand new mirrors probably have part numbers somewhere, but as usual with L/R rip-off prices the mirrors don't come complete.
Post #589303 Sat Oct 26 2019 9:14pm
McFarTech
Thanks mate. If you do have part numbers that will be grand. ===========================================
Post #589304 Sat Oct 26 2019 9:17pm
I will dig them out later but will be around a £1000.00 for new parts, or it did four years ago when I did mine. Shocked
Could try something like these.
https://www.ebay.co.uk/itm/LAND-ROVER-DISC...Sw1FdcwNCp
Post #589305 Sat Oct 26 2019 9:23pm
McFarTech
Good find thanks mate. would just need to get them colour coded to my car colour.
Not a bad price. ===========================================
Post #589306 Sat Oct 26 2019 9:28pm
Shouldn't be to far away in Maidstone at least same county. Rolling with laughter If you have surround cameras that is a bit of a problem as RRS1's are totally different to the RRS2. Might have to activate the approach lights in the CCF files if you don't have those either. Also with Disco mirror approach lights the icon will different to the Sport.
Disco
Sport
Post #589307 Sat Oct 26 2019 9:34pm
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
Col beat me to that one, McFarTech said parts numbers would be grand and i was going to say that's probably what it would cost. Smile
Post #589634 Fri Nov 01 2019 11:01am
Brit Plumber
I got mine second hand off eBay. I say second hand but by the time I’d built the spec I wanted, there was only 1 original part left and the rest was new from eBay.
What spec do you want is probably the best way to approach it. I’m assuming the minimum spec you want to be, memory, heated and puddle lamp?
I went with memory, heated, puddle lamp, camera, water wading and electrochromic (the latter not available on D4 so borrowed from an L405).
If you buy new off ebay make sure they are RHD as the frame is different between left and right, everything else is the same. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #589677 Sat Nov 02 2019 1:44pm
McFarTech
Bit the bullet and ordered the set off Ebay. should be with me this week. ===========================================
Post #592722 Fri Jan 03 2020 10:47pm
McFarTech
Guys.
So I purchased a set of Discovery 4 facelift wing mirrors. The swap over was easy and they fold in and out , can move the glass , memory function works.
However the turn signals in the wing mirrors are not coming on. Do these need coding or need activating to work? Or do I need to run some cables off the side indicator to get them to come on?
I compared the old and the new plug and everything is identical in terms of cable colour and pin placement. ===========================================
Post #593102 Fri Jan 10 2020 3:15pm
McFarTech
Here is the connection. This is from the original mirrors but the Disco 4 block is exactly the same. Ive been hunting around , they only thing I can see close to this issue is using Disco 4 mirrors on a Disc 3 and someone had to wire the green which they identified as the led positive to the side indicator positive. I have no issues with doing that if its the correct thing. I had assumed this was all plug and play.
Post #593114 Fri Jan 10 2020 6:22pm
They don't need coding, but you do need to run a wire from the side repeater to the mirror led indicator feed, as I had some spare bits of harness around just found a wire with terminal on it which fitted in to the original plug on the car and connected it to the side repeater wiring also left original repeater bulb holder in place.
They were never going to be straight plug and play as the original repeater wiring on the car is different being in the door not the mirror. You may need to activate the puddle lights in the CCF files if you don't already have them fitted.
Post #593127 Fri Jan 10 2020 9:16pm
McFarTech
Thanks mate.
Do you happen to know what wire you pin you can tapped in to? I believe it to be the green one but interested to know what you used.
I have a multimeter so can prob work it out. ===========================================
Post #593132 Fri Jan 10 2020 9:57pm
