![]() | Home > General > Help - Compressor not working |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5105 ![]() ![]() ![]() |
The compressor motor wires are easy to follow as they are thick and run from front wheel arch liner down the side.
triplemmm Member Since: 22 Mar 2014 Location: SE Posts: 79 ![]() ![]() ![]() |
Thanks Andy. So remove wheel arch liner?
Bridge the 2 large terminal holes
I bridged the relay connections but got nothing.
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
Check continuity between the relay wiring down to the compressor, then you'll know if it is actually getting power.
WIll do next as I just tried my usual mechanic and he has gone on holiday for 2 weeks!
they run UNDER the car.
Great, thanks Andy
It might.
Have you had this plugged in at all as yet? a tool that can monitor the solenoids and see what the compressor is actually doing will help here..
Can't see a GAP tool helping much, considing what you have found so far |
Given the original diagnosis..Fit a new compressor.. after:-
this is what diagnostic machines aren't the only tool required.
