Home > Faults & Fixes > Rear door will not lock or unlock with key |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
You'll need to replace the latch in the door. Common problem. Kev
Tue Oct 08 2019 8:16pm |
Smunns Member Since: 06 Nov 2018 Location: Surrey Posts: 61 |
Thanks for that and would you know the best place to get one??????? |
Tue Oct 08 2019 9:04pm |
Without knowing the year of your car, no sorry.
Tue Oct 08 2019 9:26pm |
Thanks for your help knwatkins as i will order the part from eBay as i have found one on there and have a go myself........ |
Wed Oct 09 2019 5:21pm |
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 |
Just done mine what a pain in the don't what ever you do follow powerful UK's vid remove the door handle then take out the whole assembly my swear box is now overflowing If it ain't broken down it soon will
Wed Oct 09 2019 11:20pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 527 |
It is a really common part to fail but the components are specific on year and model so make sure you purchase the right part..
Thu Oct 10 2019 10:21am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
Interesting, just replaced a rear one in mine and never removed motor from window, just dropped the whole unit motor and glass down inside the door a few inches.
Thu Oct 10 2019 10:29am |
Thanks guys you have helped me lots and think I am going to have a go on my own and see how I get on......👍 |
Thu Oct 10 2019 5:28pm |
If it's an RRS1 like mine I just removed the speaker and you can see the clip that the window attaches to. Here's the video from pwerfull uk as I said ignore the lock refitting bit, you'll never get the new one back in it was simpler to remove the lock and handle together. If it ain't broken down it soon will
Thu Oct 10 2019 5:39pm |
Aaah... you can obviously get away with it then on the RRS...i’ve Replaced them them both on a Freelander 2 and a Disco 3 (same concept ) but the design of those doors makes it easier to remove the window unless you have incredibly double jointed and dexterous hands.... Only advice is be patient and don’t try and force things.... |
Thu Oct 10 2019 11:56pm |
