Home > Maintenance & Modifications > Correct brake pads for a 2012 RRS ?
mrluke
These seem like a good buy with the additional 20% off
https://www.ebay.co.uk/itm/GENUINE-BREMBO-...3303776689
I checked eurocarparts website with my registration and these seem like the correct ones
part numbers are
P44022
P44013
Alternative PN's are
10167028A
10167022A
Any one with a 2012 able to verify ?
Thanks !
Post #587426 Tue Sep 24 2019 8:13am
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
Those are the part numbers I used and I've got a 2012, they are even cheaper if you use code sale55 on the Eurocarparts web site. £49.49
Post #587429 Tue Sep 24 2019 9:29am
mrluke
Cant seem to be able to see on their website both sets ( Front and Back)
Do you have a link ?
Thanks
Post #587430 Tue Sep 24 2019 9:35am
Tyrefitter
The link you put up is for both sets front & rear. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #587433 Tue Sep 24 2019 10:27am
david007
Thanks
Try this.
https://www.eurocarparts.com/brake-pads
Links not working now, but as Andy says, the part numbers you've listed are front and back respectively.
Even cheaper if you use Autodoc, I got a set of disc's from them the other day, had no problems and it only took a couple of days for them to arrive even as the parts have to come from Germany. Fronts £42, rears £19.
https://www.autodoc.co.uk/spares-search?keyword=P44022+
Post #587434 Tue Sep 24 2019 10:38am
Brit Plumber
Just make sure you have Brembo 6 pots on the front and not a standard 1 pot. Did all sports have big Brembos by 2012? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587436 Tue Sep 24 2019 10:55am
mrluke
The ebay link is for both sets £65
cant seem to find both sets on eurocarparts for the same price.
Post #587468 Tue Sep 24 2019 8:00pm
david007
Ah, sorry my fault, I didn’t realise that was the price for both sets, that does seem a good deal.
Post #587469 Tue Sep 24 2019 8:04pm
mrluke
Hi me again !
Taken me all this time to actually buy some and as my MOT and service is coming up thought i would replace.
The front pads P44022
I assume these are NOT for the Brembo calipers ?
As i dont think my car has these Very Happy
Everything online seems to point to these being for the normal front brakes from 05 - onwards
Post #596063 Thu Mar 05 2020 4:35pm
mrluke
It says that them pads are for the "TRW" braking system.
Does that sound right ?
Post #596064 Thu Mar 05 2020 4:43pm
DrRob
https://www.advancedfactors.co.uk/brake-parts-21-c.asp
Try Paul Redding at Advanced Bow down * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #596077 Thu Mar 05 2020 6:51pm
mrluke
For anyone searching
These fitted my 2012 AB RRS fine , i did not have brembo calipers.
here are the sensor cables also
Genuine Range Rover Sport - Front Brake Pad Wear Sensor - SEM500080
Range Rover Sport/ Discovery 3 Rear Brake Pad Sensor SOE000025 Genuine
Post #597050 Thu Mar 26 2020 6:24pm
N60613
Bosnia Herzegovina
this whare factory fitted on six piston Brembo calipers. I have tried many different pads and always come back to Jurid pads.
 RR 2012 4.4 TDV8
Post #597094 Sat Mar 28 2020 9:40am
