![]() | Home > Maintenance & Modifications > Correct brake pads for a 2012 RRS ? |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
These seem like a good buy with the additional 20% off
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
Those are the part numbers I used and I've got a 2012, they are even cheaper if you use code sale55 on the Eurocarparts web site. £49.49 |
Cant seem to be able to see on their website both sets ( Front and Back)
Try this. https://www.eurocarparts.com/brake-pads Links not working now, but as Andy says, the part numbers you've listed are front and back respectively. Even cheaper if you use Autodoc, I got a set of disc's from them the other day, had no problems and it only took a couple of days for them to arrive even as the parts have to come from Germany. Fronts £42, rears £19. https://www.autodoc.co.uk/spares-search?keyword=P44022+ Last edited by david007 on Tue Sep 24 2019 1:45pm. Edited 2 times in total |
Just make sure you have Brembo 6 pots on the front and not a standard 1 pot. Did all sports have big Brembos by 2012? 2019 5.0 SC SVA (Current)
The ebay link is for both sets £65
Ah, sorry my fault, I didn’t realise that was the price for both sets, that does seem a good deal. |
Hi me again !
It says that them pads are for the "TRW" braking system.
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025 ![]() ![]() |
https://www.advancedfactors.co.uk/brake-parts-21-c.asp
For anyone searching
N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32 ![]() ![]() |
this whare factory fitted on six piston Brembo calipers. I have tried many different pads and always come back to Jurid pads.
