![]() | Home > General > Battery Charger/ Solar battery maintainer? |
| What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112
Does anyone use a maintainer that can be powered with solar panel in the car? I'm not blessed with a garage or external sockets hence this approach.
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134
Hi,
Thanks had a look and Tim has newer model, but further digging came up with this thread
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145
If you don't have mains power, I would get a large solar panel with the OBD connector off ebay. |
that's good to know. |
Do you lock your car down in access mode as well? I believe from my wanderings around here that this also helps minimises power use- although happy to be corrected if my skim reading is wrong |
| Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 934
Lidl's Ctek clone which gets good reviews is back on sale from 26 Sept £13.99 |
| Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476
If you keep your car garaged in a garage that has no power supply it is now possible to get outside mounted small solar panels with long enough leads to get inside the garage.
Too late bought a CTEK via Amazon as needed it speedy as car didn't want to play Just put back in and all seems tickety boo, and started first twist no problem, gave it 10 mins or so running as to give the engine a gentle warm through (short on time otherwise I'd have taken it for a proper run), lets see if it starts tomorrow (locked down in access mode...every little helps The AA solar panel thingy is due to arrive Saturday to keep it topped up. Thanks all for help / feedback etc |
people have previously moaned about the reliability of the Lidl charger.
From what I have read about the Lidl charger there is only a problem if there is a power cut. It does not restart, you have to switch it back on. How many power cuts do you get? To be honest I dont know if my Ctek restarts automatically in these circumstances. Anyway if I had a power cut I am sure I would check any live sockets. For 14 quid its a no brainer if I did not already have a battery conditioner. |
The later cteks with status row of lights restart on power cut |
Lidl is 5A which is good for RRS |
| All times are GMT |
