| RRSPORT.CO.UK | ||
|  | Home > General > Battery Charger/ Solar battery maintainer? |
| What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112      |
 Does anyone use a maintainer that can be powered with solar panel in the car? I'm not blessed with a garage or external sockets hence this approach.
|  Mon Sep 23 2019 8:34am |
| riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134    | Hi,
|  Mon Sep 23 2019 10:28am |
| What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112      | Thanks had a look and Tim has newer model, but further digging came up with this thread
|  Mon Sep 23 2019 11:00am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143      | If you don't have mains power, I would get a large solar panel with the OBD connector off ebay. | ||
|  Mon Sep 23 2019 11:01am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143      | that's good to know.   | ||
|  Wed Sep 25 2019 11:01am |
 Do you lock your car down in access mode as well? I believe from my wanderings around here that this also helps minimises power use- although happy to be corrected if my skim reading is wrong  2008 TDV8 Buckingham Blue- SOLD | ||
|  Wed Sep 25 2019 11:09am |
| Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 934    | Lidl's Ctek clone which gets good reviews is back on sale from 26 Sept £13.99  | ||
|  Wed Sep 25 2019 11:18am |
| Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567    | Do you lock your car down in access mode as well? I believe from my wanderings around here that this also helps minimises power use- although happy to be corrected if my skim reading is wrong  | ||
|  Wed Sep 25 2019 3:16pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | If you keep your car garaged in a garage that has no power supply it is now possible to get outside mounted small solar panels with long enough leads to get inside the garage.
|  Wed Sep 25 2019 3:36pm |
 Too late bought a CTEK via Amazon as needed it speedy as car didn't want to play  . I've topped up the water, was tiny bit low, and ran a CTEK recondition mode over night (after taking the battery out....Jeeeebus it's heavy!!!) Just put back in and all seems tickety boo, and started first twist no problem, gave it 10 mins or so running as to give the engine a gentle warm through (short on time otherwise I'd have taken it for a proper run), lets see if it starts tomorrow (locked down in access mode...every little helps  ). The AA solar panel thingy is due to arrive Saturday to keep it topped up. Thanks all for help / feedback etc  will report back 2008 TDV8 Buckingham Blue- SOLD | ||
|  Wed Sep 25 2019 4:30pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143      | people have previously moaned about the reliability of the Lidl charger.
|  Wed Sep 25 2019 5:04pm |
| Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 934    | From what I have read about the Lidl charger there is only a problem if there is a power cut. It does not restart, you have to switch it back on. How many power cuts do you get? To be honest I dont know if my Ctek restarts automatically in these circumstances. Anyway if I had a power cut I am sure I would check any live sockets. For 14 quid its a no brainer if I did not already have a battery conditioner. | ||
|  Wed Sep 25 2019 5:36pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143      | The later cteks with status row of lights restart on power cut | ||
|  Wed Sep 25 2019 7:15pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143      | Lidl is 5A which is good for RRS | ||
|  Thu Sep 26 2019 9:46pm |
| Posting Rules
 via the towing plug on ours, but it does get parked in the garage
