![]() | Home > General > 2.7 or 3.6 |
Corgiman74 Member Since: 22 Sep 2019 Location: Scotland Posts: 2 ![]() ![]() |
Just about to purchase my first and long awaited RRS, been on loads of sites and finally found this one, so here goes. I have settled on a 2007/8, big big question for me has always been 2.7 or 3.6, I have heard so many bad stories about the 2.7 but less so the 3.6. I would greatly appreciate any advice to help make my mind up. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
The 2.7 V6 years you are looking at have an issue where the oil pump housing casting tended to break causing the engine to be totaled. If you you look for one make sure it is documented that is has been changed to a revised part, easy enough to do when doing the cam belt. And of course they can snap their crankshafts.
I myself would go for the tdv8 seeing as I’ve had 2 but mine were relatively new when I bought them,if I was looking for one now it would have to have very good history with regular oil changes as the turbos are expensive when they go,plus the suspension issues they have. Andy.
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Also don't forget to check the gearbox. I don't think it's in LR's service plan, but as it approaches 100K miles, I would recommend a flush. Also drive up a hill and accelerate from slow speed. If it judders when warm, then it could be the gearbox. a complete new one is £3K, though often it's just the torque converter, that's about £1400. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
3.6 every time. The 2.7 is a bus. 2012 SDV6 - it's missing a couple of cylinders
I've had no problems with my TDV6, but if I was to buy another, I think I would go for the supercharged (petrol). They seem to have much fewer problems. |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
3.6 it way better had my turbos changed at 108k 2800+ vat
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
A bus |
In fairness, I had a 2.7 D3 (OK so a bit heavier) but my 3.0ltr RRS is noticeably quicker. Probably the extra 50 horses. I think the later L494's had about 300bhp. Depending on your driving style, that may well be enough. When I win the lottery, the 5.0 SC will be on my shopping list though ![]() |
