Home > General > 2.7 or 3.6
Corgiman74
2.7 or 3.6
Just about to purchase my first and long awaited RRS, been on loads of sites and finally found this one, so here goes. I have settled on a 2007/8, big big question for me has always been 2.7 or 3.6, I have heard so many bad stories about the 2.7 but less so the 3.6. I would greatly appreciate any advice to help make my mind up.
Post #587316 Sun Sep 22 2019 12:22pm
gogsy1956
To be honest I think both models suffer from the same problems overall. Engine wise the 2.7 is more prone to EGR valve issues than the 3.6, but the 3.6 might have more issues with turbo's. My indie told me they saw more sized 2.7 models than most others,,,, even the 3ltr with the dreaded crank issue. It's a case of finding a well looked after example that has been regularly serviced and hope for the best and be prepared to fork out for suspension and brakes etc. Keeping the EPB serviced could save you a good amount if it were to fail. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #587318 Sun Sep 22 2019 1:01pm
Oldandconfused
The 2.7 V6 years you are looking at have an issue where the oil pump housing casting tended to break causing the engine to be totaled. If you you look for one make sure it is documented that is has been changed to a revised part, easy enough to do when doing the cam belt. And of course they can snap their crankshafts.
The V8 is generally considered to be a nicer engine, but can have turbo issues around the 100k mark (not had one myself, but have a search on here) which are expensive to replace (they have 2). And of course are worse on fuel consumption, which I suppose is relative for a big heavy 4x4.
Have a look on here for general advice regarding what else to look out for when buying one of these complicated cars.
Good luck.
Post #587319 Sun Sep 22 2019 1:09pm
Tyrefitter
I myself would go for the tdv8 seeing as I’ve had 2 but mine were relatively new when I bought them,if I was looking for one now it would have to have very good history with regular oil changes as the turbos are expensive when they go,plus the suspension issues they have. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #587333 Sun Sep 22 2019 4:41pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
Also don't forget to check the gearbox. I don't think it's in LR's service plan, but as it approaches 100K miles, I would recommend a flush. Also drive up a hill and accelerate from slow speed. If it judders when warm, then it could be the gearbox. a complete new one is £3K, though often it's just the torque converter, that's about £1400.
Post #587334 Sun Sep 22 2019 4:43pm
3.6 every time. The 2.7 is a bus. 2012 SDV6 - it's missing a couple of cylinders
Post #587343 Sun Sep 22 2019 6:58pm
CornishRob
I've had no problems with my TDV6, but if I was to buy another, I think I would go for the supercharged (petrol). They seem to have much fewer problems.
Post #587352 Sun Sep 22 2019 8:38pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
3.6 it way better had my turbos changed at 108k 2800+ vat
2.7 is very under powered
Moved on to a 5.0 supercharged AB God it’s a rocket 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #587403 Mon Sep 23 2019 4:54pm
gogsy1956
A bus Rolling with laughter Rolling with laughter Rolling with laughter 2010 RRS, TDV8
22" overfinch
Post #587407 Mon Sep 23 2019 5:31pm
Oldandconfused
In fairness, I had a 2.7 D3 (OK so a bit heavier) but my 3.0ltr RRS is noticeably quicker. Probably the extra 50 horses.
I think the later L494's had about 300bhp. Depending on your driving style, that may well be enough.
When I win the lottery, the 5.0 SC will be on my shopping list though Very Happy
Post #587427 Tue Sep 24 2019 7:21am
