![]() | Home > Technical > Random beeping |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
try pressing it anyway |
So the high spec cars have front park sensors.
Simonhunt72 Member Since: 13 Jan 2019 Location: Somerset Posts: 68 ![]() ![]() ![]() |
It does have front sensors, and they have , in the past, just stopped working, wet weather etc, both front and back , tried to hear the clicking noise but all was quiet! |
yeah the problem is when fault sensors dry out and appear to start working.
Very odd, and the damn beeping is nothing like the front and back sensor noise!!! Will have to trace the faulty one! |
maybe it isn't then?
Poss a warning!? Such a strange issue, as it went away for a few weeks then came back 10 fold haha ,maybe a trip to pick landrovers brains !!, |
I may be confusing this with another car but (a big but) doesn’t the module beep a sequence to indicate a fault, each sequence being a code? 2019 5.0 SC SVA (Current)
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
Could be thinking of this.
Valid idea tho! Where would that info possibly be? , oh ,and drove her today , no p button pressed , no bloody beeping!!!!!!🤯 |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
Once you exceed 10mph the Fronts should deactivate anyway, which are the one's the "P" switch control and reactivate once speed drops to 6mph if still switched on.
Rover75, that's true and works Haha, and magically repairs itself!!
