Home > Technical > Random beeping
try pressing it anyway
Post #585962 Wed Aug 28 2019 12:07pm
Simonhunt72
So waited for the "P" button to be lit, pressed to turn off , no beep beep!!! Turned back on when parking and all working! Clueless as to why but it appeared to quiet the beeping!!!!!
Post #586030 Thu Aug 29 2019 7:27pm
So the high spec cars have front park sensors.
And if u have a faulty sensor this can cause random beeps
Post #586036 Thu Aug 29 2019 8:44pm
Simonhunt72
It does have front sensors, and they have , in the past, just stopped working, wet weather etc, both front and back , tried to hear the clicking noise but all was quiet!
Post #586039 Thu Aug 29 2019 8:58pm
yeah the problem is when fault sensors dry out and appear to start working.
but then detect ghost objects and beep
Post #586050 Thu Aug 29 2019 10:19pm
Simonhunt72
Very odd, and the damn beeping is nothing like the front and back sensor noise!!! Will have to trace the faulty one!
Post #586054 Thu Aug 29 2019 10:41pm
maybe it isn't then?
but if it stops and soon as you press P it probably is
Post #586088 Fri Aug 30 2019 2:43pm
Simonhunt72
Poss a warning!? Such a strange issue, as it went away for a few weeks then came back 10 fold haha ,maybe a trip to pick landrovers brains !!,
Post #586089 Fri Aug 30 2019 2:54pm
Brit Plumber
I may be confusing this with another car but (a big but) doesn’t the module beep a sequence to indicate a fault, each sequence being a code? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #586116 Fri Aug 30 2019 10:16pm
Could be thinking of this.
Diagnostics.
The parking aid module has a diagnostic connection via the medium speed CAN to enable faults to be retrieved using a Land
Rover approved diagnostic system. Additionally, an on-board diagnostic routine within the parking aid module constantly monitors
the system and alerts the driver to a system fault by emitting a tone from the front or rear sounder, depending on the fault.
If a parking aid system fault has occurred, the parking aid module will relay the occurrence of the fault to the driver in the
following ways:
The status LED will flash at a frequency of 2Hz if the system is active and fault is detected in the sensors, sounders,
related wiring or the module.
The front sounder will emit an error tone for 3 seconds at a frequency of 1500Hz if a fault is detected with the front
sensors or the rear sounder develops a fault.
The rear sounder will emit an error tone for 3 seconds at a frequency of 1500Hz if a fault is detected with the rear sensors,
the switch, the LED in the switch or if there is a CAN bus error.
On-Board self-test.
As part of the strategy of the system, the self-test will inform the driver of any faults by a combination of the LED and tones:
The status LED will flash if the system is active and a fault is detected in the sensors, sounders, wiring or module
The front sounder will emit an error tone for 3 seconds if a fault is detected with the front sensors or if the rear sounder
develops a fault
The rear sounder will emit an error tone for 3 seconds if a fault is detected with the rear sensors, the switch, or the LED in
the switch, or if there is a controller area network (CAN) bus error
Post #586118 Fri Aug 30 2019 10:55pm
Simonhunt72
Valid idea tho! Where would that info possibly be? , oh ,and drove her today , no p button pressed , no bloody beeping!!!!!!🤯
Post #586119 Fri Aug 30 2019 10:56pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
Laughing They can be like that - Threats works - Sometimes Rolling Eyes
Post #586121 Fri Aug 30 2019 11:01pm
Once you exceed 10mph the Fronts should deactivate anyway, which are the one's the "P" switch control and reactivate once speed drops to 6mph if still switched on.
Post #586122 Fri Aug 30 2019 11:21pm
Simonhunt72
Rover75, that's true and works Haha, and magically repairs itself!!
Col ,thankyou, maybe it's the front with the issue
Post #586123 Fri Aug 30 2019 11:27pm
