Home > Maintenance & Modifications > Roof rails
HughN
Wales
Roof rails
Hi,
My L320 doesn't have the roof-rails into which roof bars can be fixed but, instead, has the 'blanks' that fill the same channels. Is there any way to obtain the roof rail inserts on their own? I ask because they appear to be part of a LR roof-rack 'kit' having a single part number and including the cross-bars. I've got a pair of cross-bars, just nowhere to fix them.
Thanks,
Hugh
Post #585553 Sun Aug 18 2019 7:38pm
Any good. The description is wrong though the rails are handed, the numbers they are quoteing are actualy for the plastic end cap/pieces which are avaliable seperate as a kit off 4 two front's and two rear's.
https://www.ebay.co.uk/itm/LAND-ROVER-RANG...SwR~tbqPKz
Post #585571 Mon Aug 19 2019 9:22am
HughN
Wales
Thanks, Col. Just the job. How did you find those when I couldn't? Thumbs Up
Post #585572 Mon Aug 19 2019 10:05am
Because I'm a sad sod with to much time on my hands. Rolling with laughter
Post #585573 Mon Aug 19 2019 10:08am
HughN
Wales
In that case, what fittings do I need? Very Happy
Post #585581 Mon Aug 19 2019 12:33pm
Don't need much, unfortunately none of it available separate from L/R. If you are lucky they may have saved them when removing the rails, although the plastic grommets generaly break when trying to remove them.
If you want a set of fitting instruction pm me a email address and will sent a PDF copy.
Post #585604 Mon Aug 19 2019 11:08pm
HughN
Wales
Thanks, Col. Nothing too exotic that a trip to the local fixings shop and some imagination won't fix. Very Happy
Post #585608 Tue Aug 20 2019 6:41am
HughN
Wales
I'm surprised the car doesn't need an expensive software from LR to 'enable' the roof rails. Very Happy
Post #585610 Tue Aug 20 2019 8:40am
Brit Plumber
Oh no, you’ve just given them an idea.... Big Cry 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #585684 Wed Aug 21 2019 8:54pm
