![]() | Home > Maintenance & Modifications > Roof rails |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5104 ![]() ![]() ![]() |
Any good. The description is wrong though the rails are handed, the numbers they are quoteing are actualy for the plastic end cap/pieces which are avaliable seperate as a kit off 4 two front's and two rear's.
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Thanks, Col. Just the job. How did you find those when I couldn't? |
Because I'm a sad sod with to much time on my hands. |
In that case, what fittings do I need? |
Don't need much, unfortunately none of it available separate from L/R. If you are lucky they may have saved them when removing the rails, although the plastic grommets generaly break when trying to remove them.
Thanks, Col. Nothing too exotic that a trip to the local fixings shop and some imagination won't fix. |
I'm surprised the car doesn't need an expensive software from LR to 'enable' the roof rails. |
Oh no, you’ve just given them an idea.... |
