Home > General > Juddering at 3500 refs?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. 89,000 on the clock. Just developed a very noticeable judder at around 3,500 revs??! Feels like an engine problem, I am sure wheels are balanced correctly - the feeling is not coming through the steering wheel, the whole car judders - any thoughts Andrew Kennedy
Post #584557 Sat Jul 27 2019 7:57pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Sounds like a prop shaft bearing to me! Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #584562 Sat Jul 27 2019 8:35pm
Themoog
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
Transmission failure. Sell it quickly..
Post #584607 Sun Jul 28 2019 8:37pm
ondafly
Ireland 2007 Range Rover Sport TDV6 HSE Java Black
prop shaft bearing would be my guess also. Had mine replaced last year - the symptoms were juddering around 70mph or thereabouts.
Post #584618 Mon Jul 29 2019 9:39am
Bardley
Propshaft bearing Revs related?
Unless it's always at the same speed, I would say not.
Have you tried all permutations, like gear hold in all gears to 3500rpm to make sure? 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #584638 Mon Jul 29 2019 5:36pm
Stu
Yes! The centre bearing especially has a rubber mounting and if it is damaged it won’t support the shaft properly and the faster you go the greater the vibration. Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #584645 Mon Jul 29 2019 7:45pm
Bardley
So to clarify..
Revving the engine stationary to 3500rpm has no effect on a propshaft bearing.
Road speed does.
The prop can be inspected underneath if you know what you are looking at and for. 2011 MY D4 HSE
Post #584663 Tue Jul 30 2019 11:33am
knwatkins
I agree with Bardley. Prop bearing issues would be speed related ie. rotation of the prop and not engine revs related.
Andrew, do you experience the problem at 3500rpm no matter what gear you are in/speed you are doing? Kev
Post #584689 Tue Jul 30 2019 9:06pm
andrew kennedy
Thanks for the input!!! Yes the juddering occurs at around 3,500 revs which ever gear its in. Andrew Kennedy
Post #593250 Mon Jan 13 2020 3:06pm
Themoog
Torque converter. Stick a tube of Dr Tranny in the transmission and that will fix it.
Post #593259 Mon Jan 13 2020 6:38pm
HughN
Wales
That is certainly consistent with the transmission problem I experienced (lock up clutch slipping). Cost me about £1600 for a repair. Some of the best money I've spent on the car - smooth gear-changes all the way.
Post #593318 Wed Jan 15 2020 12:30pm
andrew kennedy
Thanks for the advice!! I'll give Dr Tranny a try!! What quantiy of Dr Tranny would you suggest is necessary for a 2006 Sport gear box?? Andrew Kennedy
Post #593507 Sun Jan 19 2020 3:47pm
Themoog
Just one tube. It's American so it's in ounces. The fools.
It worked on my X5 and a mechanic friend uses it a lot when servicing high mileage transmissions.
To be honest you may cure the judder with a double trans fluid change.
Post #593510 Sun Jan 19 2020 5:41pm
gogsy1956
Torque converter issues can feel like driving across a cattle grid for want of a better description,, if your on 89k miles a megaflush is definitely on the cards,, get a couple of tubes of Dr tranny added when this is done and a gearbox reset and see how it goes. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #593512 Sun Jan 19 2020 6:13pm
Megaflush it (not the Land Rover double change which is fairly ineffective). It really needs to be flushed at 60k miles to be effective at improving the lifespan of the box.
To be honest, once the TC is juddering, anything you do (other than replacing the clutch) is just hiding the problem. It's not a cure. 2012 SDV6 - it's missing a couple of cylinders
Post #593515 Sun Jan 19 2020 7:12pm
