Home > General > Juddering at 3500 refs? |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
Sounds like a prop shaft bearing to me! Current: 2010 RRS 3.6 TDV8 HSE
Sat Jul 27 2019 8:35pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Transmission failure. Sell it quickly.. |
Sun Jul 28 2019 8:37pm |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 |
prop shaft bearing would be my guess also. Had mine replaced last year - the symptoms were juddering around 70mph or thereabouts. |
Mon Jul 29 2019 9:39am |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Propshaft bearing Revs related?
Mon Jul 29 2019 5:36pm |
Yes! The centre bearing especially has a rubber mounting and if it is damaged it won’t support the shaft properly and the faster you go the greater the vibration. Current: 2010 RRS 3.6 TDV8 HSE
Mon Jul 29 2019 7:45pm |
So to clarify..
Tue Jul 30 2019 11:33am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
I agree with Bardley. Prop bearing issues would be speed related ie. rotation of the prop and not engine revs related.
Tue Jul 30 2019 9:06pm |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 310 |
Thanks for the input!!! Yes the juddering occurs at around 3,500 revs which ever gear its in. Andrew Kennedy |
Mon Jan 13 2020 3:06pm |
Torque converter. Stick a tube of Dr Tranny in the transmission and that will fix it. |
Mon Jan 13 2020 6:38pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
That is certainly consistent with the transmission problem I experienced (lock up clutch slipping). Cost me about £1600 for a repair. Some of the best money I've spent on the car - smooth gear-changes all the way. |
Wed Jan 15 2020 12:30pm |
Thanks for the advice!! I'll give Dr Tranny a try!! What quantiy of Dr Tranny would you suggest is necessary for a 2006 Sport gear box?? Andrew Kennedy |
Sun Jan 19 2020 3:47pm |
Just one tube. It's American so it's in ounces. The fools.
Sun Jan 19 2020 5:41pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 919 |
Torque converter issues can feel like driving across a cattle grid for want of a better description,, if your on 89k miles a megaflush is definitely on the cards,, get a couple of tubes of Dr tranny added when this is done and a gearbox reset and see how it goes. 2010 RRS, TDV8
Sun Jan 19 2020 6:13pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
Megaflush it (not the Land Rover double change which is fairly ineffective). It really needs to be flushed at 60k miles to be effective at improving the lifespan of the box.
Sun Jan 19 2020 7:12pm |
