Home > Technical > Front anti roll bar pipes
Brit Plumber
I just couldn’t get them in and I didn’t fancy bending them. I tried the body mounts out to but no luck. Have you worked out how your going to bleed the system? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584003 Mon Jul 15 2019 9:28am
daxmatt
I,m changing the wishbones,so they will be out the way.
I,ll crack some joints,make sure oil comes out,I would of thought it bleeds itself,i,ll have a google
Post #584025 Mon Jul 15 2019 7:21pm
Brit Plumber
The issue I had was the mounting point, the gap between body and chassis was to small and no amount of manoeuvring would make them fit. Even taking the pipes out of the block fitting didn’t help.
With regards to bleeding, there is a procedure to follow but I ran it for a while and then bled the system later. Nearly all the air was gone but there was still some in the units. The home made kit sorted it out but I think you’d get away with it with a progressive decent drive. 2019 5.0 SC SVA (Current)
Post #584030 Mon Jul 15 2019 8:25pm
knwatkins
I hope I don't ever have to do this - it looks like a pig of a job Big Cry Kev
Post #584041 Mon Jul 15 2019 11:35pm
Brit Plumber
To be honest mate, I’ve done worse jobs. 2019 5.0 SC SVA (Current)
Post #584054 Tue Jul 16 2019 4:14pm
daxmatt
pipes arrived,all done now
[img]
[/img]
All done now Very Happy did the wishbones aswell
Post #584214 Sat Jul 20 2019 7:33pm
Brit Plumber
Did you have to lift the body? The gap looks a lot bigger than what I had available. 2019 5.0 SC SVA (Current)
Post #584217 Sat Jul 20 2019 8:37pm
daxmatt
lifted it about 40mm,just enough to get the rubber out
Post #584218 Sat Jul 20 2019 8:56pm
aaronjb
Out of interest (he says, hoping never to have to do a job like this) - how involved is lifting the body (esp. just a "bit" like that)? Is it a "four bolts and it's done" kind of job or is it a "four bolts and 12987123 electrical connectors" job?
Obviously total removal would mean disconnecting a lot of wiring, but is there a decent amount of play in the wiring for a small lift?
Oh and Daxmatt, do you own a Dax Cobra/Rush, or is the name just a coincidence? Smile 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #584324 Mon Jul 22 2019 8:11pm
daxmatt
Its just a case of the body mount bolts on the drivers side,then jack it up slightly.
Have a dax rush,not used it this year yet though Sad
Post #584335 Tue Jul 23 2019 6:17am
daxmatt
quick update,had a couple of warning lights come on dash(the body roll light),but went away after a few miles.
Done about 600 miles so far Very Happy
Post #586484 Sat Sep 07 2019 11:20am
