![]() | Home > In Car Electronics > Drivers seat cushion stuck in the highest. |
Before you go down that route, remove the cushion (4 Torx screws) and check all connections and wire condition. I have (not on my current car) had an actuator go into a geometric lock on a regular basis. If I sat in it to adjust, it would lock in the most upper position. To unlock it I’d get out and operate the switch from outside the vehicle. 2019 5.0 SC SVA (Current)
