Home > In Car Electronics > BT replacing the Ipod connection in AH2219C166AA |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
Do you have the original iPod connector cable? If so, look at pins 2 (audio GND), 5 & 6 (right & left audio) and 23 (+5V).. bell the cable out and see if they correspond to 2, 5, 6 and 23 on the car side if the car has 30 pins, otherwise that should let you map iPod to car and figure out where you need to inject signals
Mon Jul 01 2019 8:59am |
mycar Member Since: 15 Jul 2015 Location: Antwerp Posts: 17 |
Just checked with your info the Ipod connector which has pin 1,2, 19 & 20 marked if you look in the front of the 20 pins connector (not 30 btw). And of course I didn't find the pin layout of these 20 pins.... unless lauput below is the one. Note: The connector numbering seems to be different
Mon Jul 01 2019 7:32pm |
Project temp on hold due to holiday prio's. Will not put this to rest.. |
Sun Jul 07 2019 9:49am |
