Home > General > Tow bars
Akitamum
Tow bars
What tow bar does everyone have fitted and do some still use the original detachable tow bar?
We recently purchased a 2010 RRS HSE it has twin 7 pin electrics which we need to change to 13 pin, the tow bar looks like it has never been used.We go away in two weeks towing a 1800kg caravan and the tow hook just won't fit into the receiver.We have filed it and made sure the receiver is clean but it still won't fit.
If we do change it we would prefer a detachable,is there any out there for the 2010?
Post #583218 Fri Jun 28 2019 8:13pm
geoffsnook
Are you sure its the correct receiver they are know to have issues like the tow ball falling out whilst towing as happened to me and i would not put the van on the back with a tow bar that had been filed.Firstly search on here for tow ball issues i wold either buy a plate to bolt to the detachable tow bar fixing or get a fixed tow bar Thumbs Up
Post #583249 Sat Jun 29 2019 2:04pm
Akitamum
Hi Geoffsnook thank you for the reply,yes have seen and heard about the Landover towbars failing for some years now,though wasn't sure if something had changed in the mean time.
We are going to get a new towbar but would prefer a detachable though not having much look finding one,for a 20011 yes but not a 2010,I'm not sure what changed in that year if anything.
Regarding the one we have now the shape of the tow ball and receiver are the same it just won't fit in for some reason, we're not going to take the chance with it even if it did fit now.
Sorry you were one of the ones to suffer one of the failures,must of been quite frightening.
Post #583251 Sat Jun 29 2019 2:11pm
Pufftmw
I have a Trust TL1 on mine, was quite reasonably priced and I fitted it myself. It is fixed, though less obtrusive than the factory fixed unit and doesn't affect ground clearance as much.
Post #583253 Sat Jun 29 2019 2:20pm
geoffsnook
Thanks one of those things scarey at the time but hey ho have a look here if you still want to use a removable a bit of work to take it off but it's only 2 bolts
https://www.disco3.co.uk/forum/sale-detach...r+security
Post #583254 Sat Jun 29 2019 2:32pm
Tow Trust bar here too. DIY fitment. 2012 SDV6 - it's missing a couple of cylinders
Post #583255 Sat Jun 29 2019 2:53pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
I have used the factory fitted detachable tow hitches on four Range Rovers now and had had them on other vehicles without any problems! My caravan weighs in at 2000kg and I have towed cars on a twin axle trailer also. Hope you get sorted out though.. Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #583271 Sat Jun 29 2019 5:13pm
Brit Plumber
What part isn’t fitting? Is it the catch not locking in? Looking at topix, there’s no difference between 2010 and 11. There is a minor diff between 2005 to 9 and 10 to 13 but that’s it.
Can you post a photo of what you have and the lock assembly. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583275 Sat Jun 29 2019 6:23pm
riverblanche
Hi,
we have had 2xD3 and 3xRRS from 2005-2010 and used removable ones on all of them with no issues, its horses for courses we tintent a few times a year, not a horse box on every weekend Thumbs Up
as said ^ minor difference which from memory is the red locking ring as there are 2 types of replacement locks ISTR
someone could have tried to "clean it" internally and not got it back together correctly Question does the pin withdraw fully
as mentioned pics can help
oh and regarding the electrics why not get a £5 converter plug Question Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #583283 Sat Jun 29 2019 9:12pm
Akitamum
Thank you both.
Maybe a bit of a stupid question, Pufftmw does the original towbar stay on for the other towbar to attach to?
Thanks geoffsnook I have seen someone mention it on here,shame he doesn't sell them anymore though.
Post #583286 Sat Jun 29 2019 9:49pm
Akitamum
Thank you everyone for your replies.
Its the tow hook not fitting into the receiver,it just won't go in far enough for the pin to come out.
We have had a D3 before and towed a twinaxle with no problems with factory fitted towbar for a few years with no issues at all so can't understand why this just won't fit properly,it as if the receiver is to small or the tow ball to big,yet no rust,dirt or anything else in there,the tow ball looked brand new and never been used.We did think maybe it was a different towbar that had been attached though everything looks the same for the tow ball to fit in,the noggins on the side and shape.
OH was filing the tow ball slightly in the hope it would fit, unfortunately he seemed to of got carried away filing a bit more each time and filed way more than he should of done 🙈 the pin would come out in the end but not fully still,so any pressure/ force on the ball it would come out,so we definitely won't be using that one now 😂
Post #583288 Sat Jun 29 2019 10:06pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
I see that a Security plate kit is also available from Advanced Factors (forum sponsors). See here
https://www.rrsport.co.uk/forum/topic51871.html
Thinking of getting one myself.
Post #583300 Sun Jun 30 2019 9:11am
Pufftmw
Akitamum wrote:
Thank you both.
Not sure I understand the question but the TL1 has a part that fits into the receiver for LR removable towbar (it clicks in). Then there are a couple of bolts that attach to the chassis & that is essentially it.
I used the removable one for a while and it was fine but I do a lot of towing over many miles, so decided to get the extra security of the fixed.
Post #583336 Sun Jun 30 2019 9:32pm
riverblanche
Hi,
may be a bit late now if its that loose Shocked Shocked
have you tried pushing the little pin in while NOT in the RRS to see if the large pin comes out ok Question
just watch fingers and control it with the lock handle as it has some force behind it when the small locking pin is depressed
if in doubt dont do it Whistle
Post #583344 Sun Jun 30 2019 11:16pm
Akitamum
Thanks everyone.
The tow ball just wouldn't go high enough for the pin to come out,on its own pressing the little silver pin the lock would come out fine.
Pictures of the receiver,not sure i dare post pictures of the tow ball Embarassed
Post #583377 Mon Jul 01 2019 8:04pm
