![]() | Home > General > Tow bars |
Are you sure its the correct receiver they are know to have issues like the tow ball falling out whilst towing as happened to me and i would not put the van on the back with a tow bar that had been filed.Firstly search on here for tow ball issues i wold either buy a plate to bolt to the detachable tow bar fixing or get a fixed tow bar |
Akitamum Member Since: 15 Jun 2019 Location: Cheshire Posts: 17 ![]() ![]() |
Hi Geoffsnook thank you for the reply,yes have seen and heard about the Landover towbars failing for some years now,though wasn't sure if something had changed in the mean time.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
I have a Trust TL1 on mine, was quite reasonably priced and I fitted it myself. It is fixed, though less obtrusive than the factory fixed unit and doesn't affect ground clearance as much. |
Thanks one of those things scarey at the time but hey ho have a look here if you still want to use a removable a bit of work to take it off but it's only 2 bolts
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9130 ![]() ![]() ![]() |
Tow Trust bar here too. DIY fitment. 2012 SDV6 - it's missing a couple of cylinders
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 ![]() ![]() ![]() |
I have used the factory fitted detachable tow hitches on four Range Rovers now and had had them on other vehicles without any problems! My caravan weighs in at 2000kg and I have towed cars on a twin axle trailer also. Hope you get sorted out though.. |
What part isn’t fitting? Is it the catch not locking in? Looking at topix, there’s no difference between 2010 and 11. There is a minor diff between 2005 to 9 and 10 to 13 but that’s it.
Thank you both.
Thank you everyone for your replies.
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
I see that a Security plate kit is also available from Advanced Factors (forum sponsors). See here
Not sure I understand the question but the TL1 has a part that fits into the receiver for LR removable towbar (it clicks in). Then there are a couple of bolts that attach to the chassis & that is essentially it. I used the removable one for a while and it was fine but I do a lot of towing over many miles, so decided to get the extra security of the fixed. |
Thanks everyone.
