Home > Maintenance & Modifications > Cambelt TDV 3.0 |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 747 |
From memory, the 3.0ltr had a cambelt change interval of 112k miles or 7 years, whichever is the sooner. The time limit is due to the rubber cracking with age, although there will be a safety margin built in.
Fri Jun 21 2019 4:30pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
The answer depends on your attitude to gambling.
Fri Jun 21 2019 6:00pm |
Damon White Member Since: 15 Feb 2016 Location: London Posts: 62 |
Hi,
Fri Jun 21 2019 9:27pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
If the belt breaks, the engine is as good as scrap
Fri Jun 21 2019 10:30pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
As above replace it. Belt replacement, irrespective of mileage, should be done at the required time interval. Kev
Sat Jun 22 2019 9:06am |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
As Mikey. Did both mine (sdv6) bang on 7 years, mileage 90k. |
Sun Jun 23 2019 11:32am |
Mihai77 Member Since: 07 Oct 2012 Location: Geneva Posts: 30 |
Ok, so scheduled for change in a few weeks at 9.5 year old and 100,000 kilometers.
Thu Aug 01 2019 10:45am |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
Are there not two belts on the V6? Current: 2010 RRS 3.6 TDV8 HSE
Thu Aug 01 2019 8:03pm |
3 belts
Thu Aug 01 2019 9:20pm |
There are indeed two belts. One on the front of the engine for crankshaft and camshaft timing and another belt on the rear for the high pressure fuel pump, which is also timed on the 3.0 TDV6 Kev
Thu Aug 01 2019 9:22pm |
Oh yes and the aux belt as Mikey said. Kev
Thu Aug 01 2019 9:23pm |
Chain drive makes more sense to me less hassle! And should last a lifetime.. Current: 2010 RRS 3.6 TDV8 HSE
Thu Aug 01 2019 10:21pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
Except on the 5.0 when the tensioners give up and the chain slips and.... 2012 5.0 SC AB
Fri Aug 02 2019 12:16am |
Brit Plumber....OUCH!! Is that a common issue on that engine? Current: 2010 RRS 3.6 TDV8 HSE
Fri Aug 02 2019 7:27am |
