Home > Maintenance & Modifications > Cambelt TDV 3.0
Mihai77
Switzerland 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
Cambelt TDV 3.0
Driving a 2010 RRS with 99,000 km. So 9y old but still far from the required mileage. What's the experience with delaying the cambelt change?
Thanks
Mihai Gone:
2010 Bali Blue, Reverse Camera, Winter Pack, Privacy Windows, Sunroof, Steel Tread Plates.
Post #582799 Fri Jun 21 2019 1:44pm
Oldandconfused
From memory, the 3.0ltr had a cambelt change interval of 112k miles or 7 years, whichever is the sooner. The time limit is due to the rubber cracking with age, although there will be a safety margin built in.
I would suggest that you may be on borrowed time already, time wise, and it would be prudent to get it done ASAP.
Post #582807 Fri Jun 21 2019 4:30pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
The answer depends on your attitude to gambling.
I believe in service early.
Post #582816 Fri Jun 21 2019 6:00pm
Damon White
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
Interesting topic. Just purchased a December 2011 TDV6 3.0 with 37,500 miles. It's on my list of work that needs to be done.
I'm guessing its major issue if the belts breaks. I'm not a mechanic, but I'm guessing the engine would need replacing. Is this correct?
Thanks
Damon
Post #582829 Fri Jun 21 2019 9:27pm
Disco_Mikey
If the belt breaks, the engine is as good as scrap
A new engine is around £9.5k by the time its fitted
Belt replacement is £700
Shouldn't be a difficult decision IMO Thumbs Up
Due at 7yrs or 112k, whatever comes soonest
Post #582834 Fri Jun 21 2019 10:30pm
knwatkins
As above replace it. Belt replacement, irrespective of mileage, should be done at the required time interval. Kev
Post #582844 Sat Jun 22 2019 9:06am
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
As Mikey. Did both mine (sdv6) bang on 7 years, mileage 90k.
Post #582883 Sun Jun 23 2019 11:32am
Mihai77
Ok, so scheduled for change in a few weeks at 9.5 year old and 100,000 kilometers.
Interesting that on the maintenance schedule posted as sticky I can only see the 168,000 km but not the 7 years. Gone:
Post #584796 Thu Aug 01 2019 10:45am
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Are there not two belts on the V6? Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #584815 Thu Aug 01 2019 8:03pm
Disco_Mikey
3 belts Thumbs Up
Front cam belt
Rear HPFP drive belt
Aux drive belt
Post #584822 Thu Aug 01 2019 9:20pm
knwatkins
There are indeed two belts. One on the front of the engine for crankshaft and camshaft timing and another belt on the rear for the high pressure fuel pump, which is also timed on the 3.0 TDV6 Kev
Post #584823 Thu Aug 01 2019 9:22pm
knwatkins
Oh yes and the aux belt as Mikey said. Kev
Post #584824 Thu Aug 01 2019 9:23pm
Stu
Chain drive makes more sense to me less hassle! And should last a lifetime.. Rolling Eyes Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #584833 Thu Aug 01 2019 10:21pm
Brit Plumber
Except on the 5.0 when the tensioners give up and the chain slips and.... 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584842 Fri Aug 02 2019 12:16am
Stu
Brit Plumber....OUCH!! Is that a common issue on that engine? Current: 2010 RRS 3.6 TDV8 HSE
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
Post #584845 Fri Aug 02 2019 7:27am
