Home > Maintenance & Modifications > Dynamic response leak (ace fluid)
Harris.damian
England 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Hi everyone. I am new to Range Rover sports. My Dynamic response fluid (ace fluid) is leaking. It seams to be coming from where the front pipes join the valve block. It looks like someone has tryed to fix it before and done a bad job. However the pipes look new. I am hoping that it is an easy fix. From what I have read and found on the internet . I think I might be able to replace the collets around the pipes but I’m not sure if that is all that I will need. I will add a picture if I can. Any help would be very much appreciated.
Damian
Post #580826 Tue May 14 2019 5:40pm
Disco_Mikey
The seals can leak, if care is not taken when refitting the new pipes
However, the valve block can also corrode internally behind the seals, rendering the valve block u/s
It's not a cheap lump, but if the pipes look relatively new, they should come back out without too much drama Thumbs Up
Post #580842 Tue May 14 2019 9:15pm
Harris.damian
Thanks for your reply. Do you know if it’s just the collects I will need or is there o rings /seals or a gasket I will need aswell?
Post #580847 Tue May 14 2019 10:21pm
