![]() | Home > Maintenance & Modifications > Active Roll Control Module |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
i would try and 2nd hand one if cheap |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9141 ![]() ![]() ![]() |
The Dynamic Response Control Module contains two tunes - one for the TDV8, the other for TDV6 and petrol versions. Presumably the weight of the TDV8 is sufficient to require a different set up. The choice of tune is selected when the module is first installed. I wonder if this is what they are referring to. It might be worth trying a 2nd hand TDV6 one if you can find one cheap enough. Obviously avoid one from a TDV8 in case the tune choice is a one shot deal. 2012 SDV6 - it's missing a couple of cylinders
not all TDV6 had active though. |
Then there won't be a module to fail, will there? |
Even a second hand one can be reprogrammed! It’s just an EPROM so worst case is just need a reflash. Why are they saying the module is stuffed? 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Lean error on the dashboard with
It did look like it was permanently on a side slope in Wales! |
Is it defo C1A00-01 as that code suggests an issue with the wiring harness or damaged isolation switch. -04, 43,45,46 would be associated with a module internal failure. Have you checked the plug at the terrain switch? 2019 5.0 SC SVA (Current)
That's what came up on IID that I captured back in Feb though they have subsequently used another tool(s) to come up with their prognosis. The wiring & plugs have all been checked. |
